track too tight
/ track too tight #1
percy c
hazlehurst, ms
case 1150G
I have a case 1150g dozer and the tracks are to tight. I removed the grease fittings and still cant get the tracks to loosen. anyone that can help me with this problem.
/ track too tight
Have you driven it around with the fitting out?
I just walked forward and backward about 10feet. at the time it was wet and raining. have you ever heard of dirt causing them to stick.
/ track too tight #4
Welcome to TBN
On mine you have to push on the front idler to get them to collapse. Also there may be a check valve that the zerk was threaded into. Looks like a blind pipe fitting with a zerk in the end. If so it needs to come out too.
/ track too tight
I've removed the complete fitting and it still did not move. If the rain quits I can drive around the field. Do you think this will work.
/ track too tight #6
Just don't walk out of them Percy it's been a while since I had anything to do with cats so I'm not much help even though I know I've done this before.
/ track too tight #7
If you don't have anything to bump the front idlers, get western with the steering clutches while moving in high gear.
/ track too tight
That's my only fear. I hope that I can get them to loosen quickly and regrease to tighten them properly. about 15 years ago I was a heavy equipment mechanic. thats the bad part
/ track too tight
Thanks for all the info guys. Its about bed time for me. Thanks again.
/ track too tight #10
I ran into this same thing with a 450G John Deere and what I discovered is that the grease fitting threads into a check valve that is (as stated above) hex shaped. Put a socket. Check and see if this is your set up when I backed out the check valve the track looseded right up. Here is a link to what I am talking about on Ebay. John Deere Crawler Dozer Track Adjuster Valve AT159554 450 450B 450C 550 555 | eBay
/ track too tight #12
If your tracks are real dirty they will bind up,I've also had it happen in deep snow.
/ track too tight #13
Comes to mind, it takes about a 3/4" wrench to fit that check valve. If you have a 6-way blade. you can put a suitable block (6 X6 or so) between the back of the blade, and idler, angle left, and push it back.
/ track too tight #14
Percy all what I did in the past finally remembered was stick a piece of 6x6 or something in front of the track to drive against to push it back.
/ track too tight #15
Put a 4x4 between the front of the track and back of he blade. Turn the blade in slow. It'll collapse the tension cylinder and push all the old grease out.
Brett
/ track too tight #16
Good idea Brett we didn't have 6 way blades when I had to do it this would be much simpler :thumbsup:
/ track too tight #17
What Gordon says.
On my 450, the zerk threads into a check ball assembly. Yours is probably the same. Here's what my manual says to loosen the track:
"Loosen, but do not remove the adapter into which the pressure fitting (zerk) is inserted. Allow enough grease to run out until the proper track sag is reached. Tighten the adapter to 45-55 ft.-lbs. torque."
Like Gordon says, you may have to push on the front idler to get the adjuster to collapse.
Good luck with it.
/ track too tight #19
If you don't have a 6-way blade, hook a come-along to the idler wheel and chain it to a rear frame member. Be sure that side is off the ground and supported with wood blocking, not concrete, concrete will crumble with the weight. Crank it back and the grease will come out. To push it back reinsert the zerk and pump it into position with a grease gun.
/ track too tight #20
Another way to help loosen track tension after you take the check loose is to back up with a piece of firewood between the track and the sprocket just take it slow
