Rake TR3 LANDSCAPE RAKE
/ TR3 LANDSCAPE RAKE #1
razbota
any one had good luck with one? what is cost? thinking of seeding lawns @ gradeing them ect. what would be a good drop seeder ? thanks for any info /forums/images/graemlins/laugh.gif
/ TR3 LANDSCAPE RAKE #2
Hi razbota, I have a 5' TR3 and like it. Type TR3 in for a search for other posts. If you have any questions I'll try to answer them or send me a PM.
Dave
/ TR3 LANDSCAPE RAKE #3
Kioti3054...does the tr3 really save the time they claim ? could you tell us about it...is it good quailty..is it easy to use ? I am really thinking about one... they are a little high.... but if it saves time it will be worth it .....thanks bruce
/ TR3 LANDSCAPE RAKE #4
We bought one last year, it is the one they call the 3 1/2 ft. model and the finish rake is 5' to cover the wheel tracks. We have been happy with it as a tool in our lawn seeding business. It seems like we have to make a slight adjustment on it on every yard that we prep(adjust 3rd link in or out-which raises or lowers the finish rake, adjust scarifiers up or down) but once we get it set right, it works like a charm. If it is not adjusted right, it is frustrating. This winter we added a hydraulic 3rd link to our tractor to make the adjustments quicker. I am looking forward to using it again this year. The last yard that we seeded last year was really compacted as the trucks had basically used the back yard as a road to get to a location that they were hauling fill. We did have to make a number of passes, but it made the yard loose enough to hydroseed in little time. We had used a pulverizer before-it worked well, but did not level as the TR3 does and took more passes. I have never used a harley rake and have had others tell me that once you use one of those, you would never use anything else. I guess at this time we do not have need to try anything else as the TR3 has worked well for us.
/ TR3 LANDSCAPE RAKE #5
Hernando comparing the TR3 to a power rake is like comparing a Kioti to a Kubota. Is one better than the other?NO. It all depends on your needs and your ego(I'm sure I'll take a hit for that). I live in Connecticut where we have more than our fair share of New England potatos (rocks) growing. Is it as fast as a power rake? No. Is it faster than using a rake, box blade and pulverizer? Yes by far. The TR3 is all the implements in one and does all three functions in the same pass. The TR3 is built rock solid and quite heavy I have a 5' unit and it ways about 900 lbs, and yes the hyd. top link is a great advantage. For my landscaping business I use to sub all my raking to a friend of mine who has a NH skid steer w/a Harley rake. For raking, grading and seed bed on new lawn installs (and not comparing time) the TR3 does just as good of a job as the power rake. And at times I think the time savings come from his ability to spead a pile of screened top soil faster with his skid steer not the actual grading and raking. Although I think the TR3 loosens the soil deeper and grades faster. The power rake does a better job stripping off exsisting lawns for replanting. And the bottom line on speed is the ability of the operator to use thier equipment not always the equipment. Be carefull on spending big money to save time. If it takes alittle more time to complete a quality job with a hole lot less overhead it all averages out. And in the slow times your not trying to float expensive idle equipment.
Dave
/ TR3 LANDSCAPE RAKE #6
You won't take a hit from me on the Kioti vs. Kubota...we pull our TR3 with a CK20HST!!!
/ TR3 LANDSCAPE RAKE #7
Thanks, but although I own a Kioti and love it, I was just using the two as an exsample I have nothing against Kubotas or any other make. Thats my story and I'm sticking to it.
Dave
/ TR3 LANDSCAPE RAKE #8
</font><font color="blue" class="small">( You won't take a hit from me on the Kioti vs. Kubota...we pull our TR3 with a CK20HST!!! )</font>
Oh yeah? Tell me more. What size. Any special considerations to use it on the CK20? You know I have one, so give! John
/ TR3 LANDSCAPE RAKE #9
KJ,
We have what the model that they call the 3 1/2 ft. It is called that because the scarifiers work 3 1/2 ft, but the finish rake behind them is 5'. In my opinion, it is the perfect combination of tractor and implement. Hook it up to the 3 pt and go. Small enough to get in a 10,000 sq. ft. yard and big enough to do the job in little time. If the ground has been compacted it is entertaining as it works the tractor pretty hard. The tractor will snort and bellar and smoke and even have a fair amount of wheel slip. It will just spin the rear wheels if not in 4x4. As I said in my earlier post, once we get it set, we think it does a great job of prepping for seeding.
/ TR3 LANDSCAPE RAKE #10
</font><font color="blue" class="small">( We have what the model that they call the 3 1/2 ft. It is called that because the scarifiers work 3 1/2 ft, but the finish rake behind them is 5'. In my opinion, it is the perfect combination of tractor and implement. )</font>
Thanks for the reply. What kind of a price are we talking about for one that size? The Harley power rakes of any size seem to be a no go for a CK20 due to the lack of enough hydraulic flow. Not that I can afford one of those anyway! John
/ TR3 LANDSCAPE RAKE #11
The company that sells the TR3, Absolute Innovations, website has links to prices for all sizes, and a chart that recommends size to tractor horsepower. Absolute Innovations TR3 and Arena Rascal. I have a 6 foot Arena Racal that I just purchased for used with my 31 hp tractor. Have not actually used it yet.
The Harley Rakes are available with PTO drive. The versions for skid steer loaders use hydraulic motors. So the hydraulic capacity of a Kioti is not an issue.
JackIL
jusr woundering ? every seems to dodge the question this thing cost. all reserch seems most is satisfied withe the rake .but I cant see where any one will say what it cost.
/ TR3 LANDSCAPE RAKE #13
The 5' unit that is actually 6' to go on my 30hp cost me $3020.00 delivered about a year and a half a go.
Dave
/ TR3 LANDSCAPE RAKE #14
Call them 1-877-788-7253 and they will help you to pick the model to suit you and give you a price.
/ TR3 LANDSCAPE RAKE #15
The 3 1/2' unit that we bought was just over $2000 from what I can remember. We prepped over 180,000 sq. ft and used it as a drag on my rock driveway and it shows little or no wear. The price was tough to swallow at first. They gave us a 30 day guarantee, and after using it we were sold. They are built heavy and we are glad we have it now.
thanks for all info requested the video.
/ TR3 LANDSCAPE RAKE #17
</font><font color="blue" class="small">( The company that sells the TR3, Absolute Innovations, website has links to prices for all sizes, and a chart that recommends size to tractor horsepower. Absolute Innovations TR3 and Arena Rascal. )</font>
Thanks for the link, I was going to look for it when I got some time. You saved me that.
ICILED, that doesn't sound so bad a price for something that does all you've told us about. A good tiller doesn't do all of that and can easily be as much. Thanks for your reply. John
Skid Steer 3 Point Plate (A65640)
Skid Steer 3 Point...
275 Gallon Cage Tanks, Koser Safe, with 2" outlet (A62679)
275 Gallon Cage...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
2019 TRITON TRAILER ALLMAND MAXI POWER 25 GENERATOR (A65643)
2019 TRITON...
2011 WESTERN STAR 4900SA (INOPERABLE) (A65643)
2011 WESTERN STAR...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
