Towing with Lifted Truck
   / Towing with Lifted Truck #1
CLinton_in_FL
Jacksonville, FL
Is there anything to think about when towing with a slightly lifted truck. With any type of trailer, GN, 5th, or bumper pull. Just wondering before i decide to purchase a F250 that is factory lifted. Thanks
   / Towing with Lifted Truck #2
Conventional towing there should be no problem with the proper drops in your draw bars. 5th wheel and GN may cause a problem with bed and tailgate clearances.
Chris
   / Towing with Lifted Truck #3
Don't forget you lose some towing capacity with a big drop bar and that your lift springs are probably softer than stock so what you're pulling will bounce you around more. Then you also probably have bigger tires so you're stopping distances are likely increased as well.
PENDING SELLER CONFIRMATIONS (A53426)
PENDING SELLER...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A51572)
2015 International...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
TUBELINE TL50LSV LOT NUMBER 119 (A53084)
TUBELINE TL50LSV...
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A51692)
2005 Toyota Tundra...
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
