Towing with Lifted Truck
   / Towing with Lifted Truck #1
CLinton_in_FL
Jacksonville, FL
Is there anything to think about when towing with a slightly lifted truck. With any type of trailer, GN, 5th, or bumper pull. Just wondering before i decide to purchase a F250 that is factory lifted. Thanks
   / Towing with Lifted Truck #2
Conventional towing there should be no problem with the proper drops in your draw bars. 5th wheel and GN may cause a problem with bed and tailgate clearances.
Chris
   / Towing with Lifted Truck #3
Don't forget you lose some towing capacity with a big drop bar and that your lift springs are probably softer than stock so what you're pulling will bounce you around more. Then you also probably have bigger tires so you're stopping distances are likely increased as well.
2019 Ford F-450 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
LMC LOT NUMBER 139 (A53084)
LMC LOT NUMBER 139...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2006 CHEVROLET EXPRESS CUTAWAY BOX TRUCK (A52577)
2006 CHEVROLET...
EZ-GO Textron Electric Golf Cart (A51694)
EZ-GO Textron...
