Towing Hitch
/ Towing Hitch #1
kjm3232
Northwest Mass
power-trac 1430
Was there a modification made by someone to the towing hitch on back of the 1430 or higher models so you can put some sort of towing adaper on the back and pull a standard trailer around the property? thanks
/ Towing Hitch #2
I welded a 2 in receiver on the back of my 1445. I think Fourteen and several others have done something similar.
/ Towing Hitch #3
Not sure if you are referring to mounting a hitch without welding but if so there is an extensive post on this somwhere. If this is what you are looking for I'm sure it can be found - I did somewhat the same to be able to tow my dump trailer from the rear. It is a two inch hitch cut down in length and shaved on top and bottom with a new hole drilled vertically to allow use of the existing pin.
/ Towing Hitch #4
Did a bit of research and think it may have been Fourteen who first did the hitch for the rear. I tried to find the series of posts where pictures were posted of the entire process but can't seem to find them. Perhaps someone has a better recollection than I and can point you in the right direction.
/ Towing Hitch #5
Don't know if Fourteen was first. I think I may have beaten him. I cut off the pin hitch and welded a Reese 2" hitch across the back. I think the pictures may be in the modification forum, since PT didn't have one back then.
The dark ages,:cool:
/ Towing Hitch #6
You may be right about cutting off the pin hitch but I think Fourteen did it the way I did without cutting off the pin hitch but inserting the tube between the the existing hitch and pinning it from the top. Thus it is removable, required no welding and can be reverted to the pin hitch.
/ Towing Hitch #7
This is a picture of the 2 in receiver I welded on the around Aug 2004.
/ Towing Hitch #8
Charlie's hitch
/ Towing Hitch #9
And if you need several ball sizes and a clevis (and an air filter - also posted i n the 1850 thread.)
/ Towing Hitch
Yes that exactly what i'm looking for. I don't have a welder but seeing that picture you supplied means i can figure out how to make one like it. thanks again.
/ Towing Hitch #11
Gee Charlie, That looks like one of those air boats down in the Everglades. You could put the grapple on and do some gater hunting.
/ Towing Hitch #12
I did one for the 422. Maybe it is relevant. I know that I am pasting this wrong, but here is the link
http://www.tractorbynet.com/forums/showthread.php?t=81900
Edit: I welded my hitch together, (but I think it could be bolted), and the bolted it to the PT422
2025 Pabreak 80in. Skeleton Grapple Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2012 Isuzu NPR HD w 5.2L 4HK1-TC Turbo Diesel (A63689)
2012 Isuzu NPR HD...
17601CFL (A59228)
17601CFL (A59228)
Amadas SPC-6 (A64119)
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
Cat CB24B (A60462)
Cat CB24B (A60462)
