Towing a not running 03 Bobcat'
/ Towing a not running 03 Bobcat' #1
AJP123
Duvall, wa
bobcat 753
What is the trick to allow hydo tranny to free spool to tow bobcat onto trailer? Imagine there is some valves to open close.... Please educate
/ Towing a not running 03 Bobcat' #2
There are no pressure release valves or "tow valves". Best to either drag it, or try using bungy cords to hold the steering levers at full stroke in dirtection you are pulling it. This can reduce some of the back pressure on the motors.
Thanks for the input' I have worked on older ones 86-89 and they had bypass valves under the seat, this newer one had me stumped and towing some of these hydro-static transmissions can damage them
Do you have a good price contact on parts? like a loaded or unloaded cylinder head? looks like the spring loaded fan belt idler was stuck in a unloaded position and rig overheated cracking head.
