towing a hydro tractor
/ towing a hydro tractor #1
frankie14001
akron,n.y
kubota L3130
the other day i had to tow my neighbors tractor it got me thinking about my tractor.i have a kub 3130 hydro does anyone know the proper steps to take if you have to tow your tractor if engines not running.i looked in owners manual but could not find any info. thanks in advance
/ towing a hydro tractor #2
My BX is hydro. Didn't read in the manual, but logic says put it in Neutral. Since the tractor ROLLS free in N, towing it a short distance in N shouldn't hurt it. I'd make sure it's not in 4WD too.
ron
/ towing a hydro tractor #3
ron
Yep, I agree with Ron. You can also lock the clutch pedal down which is what they recommend for long storage times without use.
ok i was just wondering cause on my zero turn mower you have to disengage a lever on the tranny before the wheels would free spin but that dont have a clutch thanks for the replies
/ towing a hydro tractor #5
No "clutch" and mine dont roll at all in "neutral"??? Or do you mean "neutral" as far as a "speed range" goes??
/ towing a hydro tractor #6
I was woundering that too.
Does anyone know the sequence of these units?
Logic says that is should be:
Engine -to- clutch -to- hydro trans -to- range trans -to- transfer case (front and rear) -to- differentials
Would seem the most reasonable but that doesn’t always mean anything.
This also reinforces the need to always set your parking brake when ever you get off of the tractor. If for some reason, intentionally or un-intentionally, you leave the range trans in neutral you could lose your tractor and/or hurt someone.
If the range trans is between the hydro and the differentials, putting it in neutral would serve the same purpose as the disengage levers
/ towing a hydro tractor #7
Put it in Neutral Speed Range between L, M or H. Take it out of 4WD.
/ towing a hydro tractor #8
It is engine > hydro > range trans > transfer case > differential > wheels
Putting the range in N will disconnect the wheels from the hydro and be safe for towing.
paul
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
KBH Tank Trailer (A63688)
KBH Tank Trailer...
Adams 5T HC (A63688)
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
INSPECTION (A65563)
INSPECTION (A65563)
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
