Towable manlift
/ Towable manlift #1
fabricator01
IH and David Brown
Hello all, I am building a towable manlift to make servicing my tracking solar array easier. I have two cylinders, one on a lower boom and one on an upper boom, and two short single-acting cylinders to give about 45 degrees of rotation. I have it hooked up to an international 544 tractor. The tractor has one manifold with two sets of quick couplers, one set is hooked up to a loader on the front. The other two I have hooked up to the manifold these three valves are on and my cylinders are attached to them. My problem is everything operates to jerky, all or nothing. It's more like a trebuchet than a manlift, what could I do with what I have here to make things operate more smoothly?
I tried to upload an image of my vickers valves but I can't for some reason.
/ Towable manlift #3
Welcome to TBN.
You can't post pictures until you make I think 5 posts. ;)
/ Towable manlift #4
Some 5000# hard seat 1/2” needle valves. About $25 on eBay. Be able to throttle your flow. Also if placed right able to be lock valves to take in use pressure off hoses and be safer?
/ Towable manlift #5
Are you using electric controlled valves? Manual valves of decent quality should be able to control the flow.
/ Towable manlift #6
I suspect 4570man is correct in the use of Vickers D03 solenoid operated valves so could have toggle switch in basket and valves on frame.
For remote control of electric operated valves with feathering or metering you need to proportional control.
/ Towable manlift #7
I would recommend that you also use some pilot operated check valves,
they will not allow a cylinder to float or drift down,or just blow a line and drop.
/ Towable manlift #8
I should have been clearer. The needle valve acts as a flow control device like an orifice or snubber to control the speed. An adjustable orifice. Adjust your speed but still use your current control valve. Not real clear what type of control valve you are using. Pictures of what your doing will be appreciated. Many of us have thought about the same thing.
/ Towable manlift #9
I’ve used commercial man lifts that worked that way and they really suck. Trying to steer using a switch is about impossible and like the op is experiencing there’s no control. The swing is especially bad. The pistol grip hydraulic controller in my bucket truck was far superior. Also the bucket truck had massive cylinders like an 8” bore which couldn’t have been necessary for the load. The best reason I can think of is they’d keep the hose pressure low which would reduce the chance of failure and with the large volume they’d move more precise. Also every bucket truck, boom lift, crane, designed for lifting has check valves that won’t let it drop in a hydraulic failure.
/ Towable manlift #10
Am I missing something if I suggest simply reducing RPM on the tractor while using the man lift?
/ Towable manlift #11
How high does that thing go? I would not go up any height in a lift that did not have the cylinder safety devices found on commercial lifts.
Possibly an accumulator would help with the jerkiness.
I would go flow control before using a needle valve. Someone installed a needle valve on my Kubota (Bradco) backhow swing cylinder and I hate the way it operates. It's dead slow or no effect at all in adjustment. And cavitates!
3 Point Hay Forks (A62613)
3 Point Hay Forks...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
(4) MOUNTED 2000 LB TRAILER JACKS (A64280)
(4) MOUNTED 2000...
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
