Tow Along Generators
/ Tow Along Generators #1
Neat 1500
Platinum Member
Queensland,Australia
Only a YM14 MkII
Work bought 4 tow along generators to power the signals when we have power interuptions or if power lines come down etc, i know they are made in china so they are fairly flimsy in the construction. today i had to check on some wiring internally to find they have Yanmar 3TNV82A in them with a UK made AC alternator. pity the rest of it wont last as long as the motor should going on some of our tractors that are 30+ years young and still going strong.
/ Tow Along Generators #2
That does not seem to leave much to be made in China.
/ Tow Along Generators #3
All those electrical componets and wirering that we find in things from Harbor Freight. :D
Should ahve said "assembled" in china.
/ Tow Along Generators #4
I have bought & sold a few diesel gen sets.
Lately I have run into generators that are badged as Yanmar, but they are obviously made in China, with fake Yanmar engines !
You can see them on Craigs list.
You gotta watch what you are buying now days.
There is a lot of chinese smoke & mirrors for sale :confused2:
/ Tow Along Generators #5
I think 'Small Yanmar Diesel' now just means its parts are interchangeable with Yanmar, if it's made in China. I haven't read of Yanmar manufacturing there, but the example of Perkins is pretty recent.
Perkins Diesel wanted to enter the China market so they built some co-owned assembly plants there. Then after a little while Perkins was thrown out and the China Perkins Diesels continued to be manufactured. China essentially said 'so sue me'. Good luck with that in the courts of China. Same thing happened to Chrysler's Jeep. First a co-manufacturing plant, then a China-owned replica plant that built the same thing without paying royalties to Chrysler. China's patent law is totally different than we are familiar with. Essentially once a design appears inside China, its theirs to use as they wish.
/ Tow Along Generators #6
There is no Yanmar plant in china that makes generators.
The chinese copy a yanmar generator, and put phony Yanmar tags on them.
The castings were rough, and everything else screamed chinese at ya.
I saw one with my own eyes, just cruise Craigs list, and drive to go see one.
There ought to be laws to stop this phony practice :mad:
/ Tow Along Generators #7
Has anyone tried a PTO driven generator?, I have seen them for sale but normally too large for a tractor my size (YMG1800D) but I am sure they make smaller PTO driven units, it would be nice to have one at our house in the country when the power goes out, now I just have a 6500 watt to power emergency items but I would think a 20hp diesel would turn a 5k?
yeah i also thought this Ernie but it looks to be well made. the cast is good and all its accessories have well made brackets and the like so maybe not? i will have a much closer look at them tomorrow and see what it can find,BTW even the grey paint job on them is flawless,i will take some pics and post them.
/ Tow Along Generators #11
The last one is hilarious! Free headland with deisel generator purchase. I was like what do those have to do with each other and who is spending $600 to get a free $15 headlamp free. Then it came to me power out, you need light to try and start up you china made genset.
/ Tow Along Generators #13
A few things to consider:
It takes about 1 HP to produce 750 watts of 120, so a roughly 20HP (PTO) could produce around 15,000 watts. That is about what most residential "standby" units produce (in the 12-20K range). The real problem is the consistency of the RPMs _AND_ the "clean-ness" of the power produced. To produce effective power, the genset must spin at more-or-less precise, exact and constant RPMs - that's why gensets have set speed governors, not throttles. Then, the power produced must be usable, through a transformer, an inverter, etc. If you look at the power output of many inexpensive "homeowner/contractor" type gensets, they are spiky and not uniform. They'll happily run "simple" electrical devices like circular saws, incandescent lamps, space heaters, etc. But you'd not want to connect your sophisticated battery charger, your computer, your ham radio, etc. to them. OTOH, the more sophisticated "consumer/contractor" gensets, like the Honda EU series, produce "sine wave" power via an inverter.
The bottom line is that, yes, from a horsepower standpoint, your tractor can and will supply a fair number of watts, but what you can do with them will depend on the genset's construction. For me, a tractor-powered genset is not really suited to emergency-power to a modern home _unless_ the system is very well thought out and constructed. And that costs money, esp. so since the market for such is much smaller than for stand-alone gensets that do the same thing. My advice would be, if you need/want more than 6500 watts for your home, buy one of the home standby units and if you need more for use at construction sites, etc., buy one of the larger roll-around style portables.
Hope this helps.
/ Tow Along Generators #14
Take a look at this link - I like the one I have from Harbor Freight. Most others are made for BIG tractors _ expensive, designed to keep dairy farms running.
Mf
http://www.tractorbynet.com/forums/attachments/161731-harbor-freight-power-take-off.html
the"quite" generators we can also buy here and have. they are blue but it is the same unit. 1 cyl diesel, will run for about 8 hours on 5 odd litres. we payed about $1100 AUD for them. the only problem with them is they dont recharge their own battery so after a few starts it wont turn over fast enough to fire up. apart from that for the price they were good and so thought the thieves that stole 3 of them from signal sites:mad:
/ Tow Along Generators #16
Not quite, 1 hp=746 watts BUT 10 hp will not drive a generator to produce 7.46KW!!
Losses, mechanical and electrical. You'd be lucky for 1HP to produce 500 watts in the real world!!
The best rough guide for PTO gennies is 2HP for every KW, BUT, thats a rough guide. Remember in the real world nothing is 100% efficient. The most efficient machine in the world is the bicycle!! Next is a well designed transformer with up to 98% efficiency.
PTO generators have a gearbox, your tractor has a gearbox, friction, electrical losses given off as heat.
/ Tow Along Generators #17
I agree there are substantial losses between burning diesel and creating watts. But the tractor's hp is rated at the output of the pto, so you can ignore the tractor's internal losses in estimating what size generator it can power.
I think the practical limitation on powering a generator with these elderly Yanmars is that the cooling system needs to be brought up to like-new before you could run continuous at full rated horsepower output.
And another thought from prior threads: When your grid power is down is when you are likely to need the tractor to move fallen trees etc. A standalone generator might make more sense if that is when you will use it.
I took one in for service today and had a good chat with the agent and he says they are japanese built yanmar engines not chinese. he has sold many of them around australia and new zealand and had no major issues with the engines. typical yanmar :thumbsup:
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
(12) SKLP SK-LJB-12 Polyethylene Roadbed Protection Pads (A60463)
(12) SKLP...
2018 Bobcat T770 (A60462)
2018 Bobcat T770...
LOT LOCATIONS (A59906)
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
2019 INTERNATIONAL LT625 DAY CAB (A60736)
2019 INTERNATIONAL...
