Tough to move pallet forks
   / Tough to move pallet forks #1
ning
Elite Member
Northern California
Branson 3520h
I've got a set of forks (Titan) and it's really tough to move the forks in or out to different "settings". Note I'm not talking about the SSQA connection - this is the fork itself which has a little spring catch at the top and it's supposed to be able to be moved to various positions in the frame.
Anyone have any hints on how to make this easier? it seems to me that the hook part of the fork at the top isn't particularly open and square and instead narrows more tightly than the part of the frame that it's supposed to ride on. I'm thinking of using some tool, but doubt my 4.5" grinder is the right one.
   / Tough to move pallet forks #2
I have the same forks and had the same problem. I pounded the two spring latches off with a hammer and punch. Now the forks can be moved with a pry bar.
   / Tough to move pallet forks #3
I find forks always hard to move. It's why I love my hydraulic ones.
There is two issues. One is the locking mechanism and the other is actually moving them. So, you are saying, they are not unlocking? Does the spring catch stay in the unlocked position or do you have to hold it?
Yes, out of frustration I have removed the latches from forks as well. As long as they can't get off the ends, I don't see the danger.
They unlock readily, and the spring drops the catch into the detent just fine. The problem I've got is with the "sliding" of the fork from one position to another. Last time I did it I kicked it for a while and got one to move a bit, and the other to move enough... not all the way to another detent, but for what I was using the forks for it didn't really matter, but it's still a PITA. I'm guessing a hand sledge with a wood block may help, but the tractor was here and the sledge was there and I'm lazy, it's why I've got the forks :laughing:
It seems to me that enlarging the slot that holds the fork at the top of frame, making it a proper square, would go a long ways to making these move readily, so that the catch would actually have something to do. It takes a *lot* of force to move them right now.
   / Tough to move pallet forks #5
I have similar forks with top spring latches that lock them at specific widths. They were hard to slide wider or narrower. I slid each one (one at a time) to the center and applied a heavy layer of grease to the points of contact then slid the forks back and forth. They slide much easier with a good coat of grease. Just have to remember not to lean against the fork carriage so I don't get grease on my clothes.
   / Tough to move pallet forks #6
I don't remember what brand my forks are but I found if I release the top pins, have the forks about waist high and tipped slightly down, I can just lift slightly with one hand at the center of the forks, then use the other hand to slide the vertical part. Doing it that way they move fairly easy.
   / Tough to move pallet forks #7
Mine are same. Basically "rocking" them does it. Push at top by latch, then push on bottom of forks (read:kick)...so kind of rocking them with the pin unlatched and they will wiggle across the frame in/out. Very rarely do they just slide to where I want them the way I think they should.
   / Tough to move pallet forks #8
I also raise my loader a bunch and point the forks almost straight down. This relieves the pressure of gravity and they slide easier
   / Tough to move pallet forks #9
I have kicked a lot of them and used a sledge and block of wood. That only works when the catches stay unlocked or are gone. Sometimes tilting the forks down at a certain point makes it easier.
I like the tilting idea and will couple it with grease... but ideally I think I'd like the grind or saw out the notch to make it fit right (pretty sure all of these types of fork blades are made-in-China and I'm not surprised that they're not quite precise).
If anyone's done such a cleanup mod, please let me know; for now it's probably going to be a "deal with it you don't do this often" kind of thing.
Thanks!
LOT: (48) 2.5 Gallons of Star Fire Diesel Exhaust Fluid (A59076)
LOT: (48) 2.5...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
204549 (A52707)
204549 (A52707)
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2021 Nissan NV2500HD Cargo Van (A56858)
2021 Nissan...
