Torsion axles???
/ Torsion axles??? #31
Are you sure a 14K trailer is going to be enough? Even a 20 feet long flatbed (which is fairly short) usually weighs between 4-5K pounds, empty. That leaves 9-10K of capacity. Some trailers rate their GVWR with some tongue weight, but not all. If it's a longer trailer, it'll take that much more out of your carrying capacity.
You mentioned a dozer-those are usually heavy. Recently, I pointed out to our County Road Crew they were putting a 25K backhoe on a trailer with a GVWR of only 22,500. The **** thing only has around 15K capacity. They are now shopping for a new trailer.
/ Torsion axles???
It is a little Mitsubishi dozer and weighs a little over 9K. For the last ten years I have been hauling it on a 12K 16' Top Brand trailer. Trailer has handled it fine. I know it loaded at gross. No damage to trailer. It is built as heavy as some rated 14k trailers. But at times I thought if I run on to the right trailer and the right deal I would step up to a 18' with 14GVW because when I haul my Kubota tractor with FEL and a bush hog on it, it is a tight fir. Finding a used one is pretty hard because I want a low slung one, 16' with 2' beaver tail. The trailer I have really handles it nice. And if you find a used one at a good price, they are pretty well beat up. I think I have pretty well decided not to go with the Corn pro. I have found a 14 GVW Land Trail. But it needs a lot of work. New tires, wiring, fenders repaired, and the under carriage should be sand blasted and repainted.
/ Torsion axles??? #33
Man, I would LOVE to have one of those little Mitsubishi dozers.....someday.
/ Torsion axles??? #34
I have 0 need for a dozer myself, my box blade covers my needs. But for some reason owning a dozer is on my bucket list.
/ Torsion axles??? #35
Here a pond, there a pond, everywhere a pond, pond!
/ Torsion axles??? #36
Item 2 on the bucket list is an excavator, which would be a bit more practical. Tracked & has a dozer blade, at least for most minis. But somehow not as cool as a dozer. Would be better for pond building though. ;-)
/ Torsion axles??? #37
A dozer is the ultimate man toy. Nothing like going up to a tree and just pushing it over. Rubber only last so long. A steel spring really only wears out from use where as even sitting the rubber in the torsion axle is still going to be hardening. I've got a tri axle trailer that rarely gets used built in the 70s that still has the original springs.
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
CAT 336E (A58214)
CAT 336E (A58214)
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
402 (A52706)
402 (A52706)
