torquing a ball
/ torquing a ball #21
Well it seemed like a lot of torque when I was sitting on the end of that wrench last night! I think I got them more than tight enough, and also used blue locktite for some insurance and paint-striped the bolt/nut as alancamby suggested. Will periodically check everything whenever I tow, of course.
I thought about firing up my impact gun, but it's a 1/2" unit and all of the 1-7/8" sockets I found were for 3/4".
Interestingly, the 2" ball snugged to the point where I only needed to wrench on the nut to tighten it all the way home. The 2-5/16" ball kept wanting to spin so I had to wedge a pipe wrench between the flats on the ball base and drawbar to snug it up.
Thing is, if you go dry and very tight it can still be removed w/o holding the ball. With loctite you will be pretty stuck. .. Torque spec for a 1.25" Gr2 thread is 675 ftlb. For Gr5 its 1200 ftlb. If people would just tighten more than finger tight there would not be any risk of loosening.
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
IRanch High-End Tricycle (A64119)
IRanch High-End...
2006 Mercury 115ELPTO 115hp Outboard Boat Motor. (A66738)
2006 Mercury...
DRIVE WHEEL W/ PUMP (A65054)
DRIVE WHEEL W/...
THE MACHINE CO. THAWZALL H250 HEATER (INOPERABLE) (A68842)
THE MACHINE CO...
Komatsu PC220LC7 Thumb Jaw (A68134)
Komatsu PC220LC7...
