Torque Stats
   / Torque Stats #1
OakHillFarmer
Pepperell, MA
Kubota L4330 HST, R4's, HD Quick Attach bucket
Does anyone know the torque stats for the TC40, 45, 48 and 55? I can't find these stats online and I want the exact numbers for comparison. The dealer is closed but I'll call tomorrow if I can't dig them up.
I want the max torque at rated engine speed for an accurate number.
Thanks,
Mark
   / Torque Stats #2
Mark, I checked the engine section of my Repair Manual and there are lots of specs on tolerances and clearances, but no engine torque specs. Only the gross HP is listed. I don't know that I've ever seen numbers on torque or seen torque vs. HP curves anywhere.
   / Torque Stats #3
I would like to know also, and looked hard for that info. I suspect that the older 2120 tractors may have produced more torque than the newer engines.
   / Torque Stats #4
HP = RPM*TORQUE/5252
TORQUE = HP*5252/RPM
Use engine HP & RPM (~3,000+/-) if you want available engine torque
Use PTO HP & RPM (540) if you want available torque at the PTO
This calculation may not give maximum torque (which is usually available at lower rpms), but deisels have pretty flat torque curves, so should be a reasonable comparison...
Edit here
All models are gear trans (you didn't specify)
HP PTOHP RPM Eng Tqe PTO Tqe
40 35 2600 80.8 340
45 39.6 2600 90.9 385
48 40 2800 90.0 389
55 47 2700 107.0 457
2014 Ford Escape (A50324)
2014 Ford Escape...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
Club Car Electric Utility Cart (A51694)
Club Car Electric...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2021 International HV507 4-Door 4x4 12ft Dump Truck (A51692)
2021 International...
