Toro with 16 hp vanguard dies suddenly
   / Toro with 16 hp vanguard dies suddenly #1
brushpyle
I have an older model toro 3050 greensmaster. The motor is a vanguard 16 horse. The mower will start and run fine for about 10 mins then sputters a bit and dies when under a load. It will restart sometimes right away and other times you have to crank it a while. Using the choke does not effect it's restarting. I have checked the solenoid at the base of the carb and it seems to be working fine. I even by passed it. I found a cracked line coming from the valve cover and replaced it with new. I have replaced the plugs and installed a new fuel pump. Still does the same thing. I even tried it without the gas cap on. Any ideas on something I'm missing. safety switches appear to be in working order as well. Thanks
   / Toro with 16 hp vanguard dies suddenly #2
Have you checked it for spark when it dies?
Don't have anything other than pulling a plug wire. Narrow it down to ignition or fuel. I'm on it first thing in the A.M. Thank you. Will report back
   / Toro with 16 hp vanguard dies suddenly #4
When it dies stick a screwdriver in the plug wire and hold the plastic handle and hold the screwdriver close to the engine and watch for spark to jump.
Thanks guys. I have it running like a champ. The guys check the gas with a stick. Over the years I found a bark buildup in tho pitot. Thank you. Rod
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
434669 (A48836)
434669 (A48836)
CAT 973 (A47384)
CAT 973 (A47384)
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
2018 John Deere 1653 (A55302)
2018 John Deere...
