Toro with 16 hp vanguard dies suddenly
   / Toro with 16 hp vanguard dies suddenly #1
brushpyle
I have an older model toro 3050 greensmaster. The motor is a vanguard 16 horse. The mower will start and run fine for about 10 mins then sputters a bit and dies when under a load. It will restart sometimes right away and other times you have to crank it a while. Using the choke does not effect it's restarting. I have checked the solenoid at the base of the carb and it seems to be working fine. I even by passed it. I found a cracked line coming from the valve cover and replaced it with new. I have replaced the plugs and installed a new fuel pump. Still does the same thing. I even tried it without the gas cap on. Any ideas on something I'm missing. safety switches appear to be in working order as well. Thanks
   / Toro with 16 hp vanguard dies suddenly #2
Have you checked it for spark when it dies?
Don't have anything other than pulling a plug wire. Narrow it down to ignition or fuel. I'm on it first thing in the A.M. Thank you. Will report back
   / Toro with 16 hp vanguard dies suddenly #4
When it dies stick a screwdriver in the plug wire and hold the plastic handle and hold the screwdriver close to the engine and watch for spark to jump.
Thanks guys. I have it running like a champ. The guys check the gas with a stick. Over the years I found a bark buildup in tho pitot. Thank you. Rod
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
Hilti TE 2000-AVR Electric Jack Hammer (A52377)
Hilti TE 2000-AVR...
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51406)
2016 KENWORTH T270...
2022 KUBOTA MX5400 HST TRACTOR (A54607)
2022 KUBOTA MX5400...
