Toro Wheelhorse sputters under load
   / Toro Wheelhorse sputters under load
It's not "only has issues when on a hill". If I"m on flat ground and pull the PTO for the mower blades, it does the same thing. It's when under load ....and high throttle (but I run all my other machines at full throttle).
   / Toro Wheelhorse sputters under load #12
OK, then back to what others have said, fuel or poor spark.
   / Toro Wheelhorse sputters under load #13
Does this model have one lever for both choke and throttle or two independent controls. If one is it adjusted properly so not running partial choke when you think still only throttle?
   / Toro Wheelhorse sputters under load #14
That is a rich sputter not lean. List the model type code numbers from the engine so we can see what carb that engine has. May not be carb related could be a valve, camshaft issue.
Briggs model: 286H77 type: 0165 E1
Yes, only 1 control for both choke and throttle. I'll check adjustment! Thank you
   / Toro Wheelhorse sputters under load #17
If this had the Nicki carb I would bet the high speed jet fell out. You said you replaced the carb from Amazon, which if they cause problems are normally to the lean side. Wouldn't be a bad idea to check valve clearances, and also roll the engine over by hand making sure both valves are opening the same distance. The issue could be a sign of a worn cam lobe causing one valve to fully open and stay open long enough to do its cycle. Your issue sounds like incomplete combustion under load.
   / Toro Wheelhorse sputters under load #18
Maybe check the jet size, just got a replacement carb for a chinese ATV and the main jet in the new one was just over the half the size of the old jet. Installed old jet in new carb and it runs fine under load, when it would not with smaller jet.
Thank you all for your help. I went back to the original carb, cleaned it (again), and the machine is running pretty well. I ordered a new (OEM) ignition coil and did clean the fly wheel magnet. Hopefully she stays happy!!! Thanks again
2018 John Deere 460E Articulated Dump Truck (A53472)
2018 John Deere...
2017 Ford Explorer SUV (A51694)
2017 Ford Explorer...
2010 Chevrolet Tahoe SUV (A52377)
2010 Chevrolet...
CONTACT INFO LOT IDENTIFIER 6 (A53084)
CONTACT INFO LOT...
BAUMA LIGHT TX 12 LOT IDENTIFIER 225 (A53084)
BAUMA LIGHT TX 12...
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
