Toro mower model #26622 leaking gas bad!
   / Toro mower model #26622 leaking gas bad! #1
shortlid
Derry, NH
Well now have the blades engaging right but the thing is leaking gas BAD. Tried removing carb. spraying out with carb cleaner and replacing carb bowl gasket still leaking bad. The replacement carb. is over $150 more than he paid for the mower. My brother is about to bag the whole mower. Rebuild kit soaking in carb cleaner over night. The local mower shop will not rebuild the carb.?:(
Can this engine be converted to a Walbro carb. one that parts are easier to find? When he looks at the carb float he says it does not look like it is attached to anything? Is theer suppose to be a linkage from the float to a valve to shut off the fuel flow?
Here are pics
   / Toro mower model #26622 leaking gas bad! #3
It is missing the float needle and spring. This allows the float to regulate the amount of gas that is in the float bowl. Without it, as you discovered, it just overflows. Should be an easy thing to pick up at a small engine shop. The spring attaches to the lip on the float, and the needle goes inside the hole at the bottom of your second picture.
-Fordlords-
-Fordlords-
AWSOME info, thanks so much picking them up now. LOVE THIS FORUM!!!
Wow seems like alot of parts are missing from this carb. You think some one messed with it before my bro bought it, OR did these parts rust away to the rust we found in the in the bowl while siting for awhile.
Well the needle rusted right out of the carb. Due to the disimalar metals in the Mikuni carbs. Once we cleanre s the rust chucks of where the needle shoudl be and put a new needle and seat in it started on the second pull and did not leak a drip!!
1984 Crown Victoria Sedan (A52377)
1984 Crown...
2001  WABASH 53FT DRY VAN TRAILER (A54607)
2001 WABASH 53FT...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
2004 INTERNATIONAL 4300 BOX TRUCK (A54607)
2004 INTERNATIONAL...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2011 INTERNATIONAL DURASTAR 4300 M7 BUCKET TRUCK (A51406)
2011 INTERNATIONAL...
