Toro Groundsmaster 322D fuel issue
   / Toro Groundsmaster 322D fuel issue
well installed the line on number 1 cylinder, turned the motor over to bleed the line at the injector and as much as I tried the motor refuses to fire, not even any smoke, the lift pump is running, Im thinking it shut down from no fuel so when it stops raining plan on bleeding the system starting with the rubber lines then the injectors.
am I missing anything? now its not getting any fuel whatsoever
   / Toro Groundsmaster 322D fuel issue #12
fuel shutoff is working as it should, bled air out the system, it was obvious when I loosen the line on the injectors 1 and 3 made little difference but 2 was obvious the rpm dropped, still thinking its air but started pouring down, will take another look tomorrow
   / Toro Groundsmaster 322D fuel issue #14
laurencen spray your ignition with a silicon spray that should help to
lub parts to keep from sticking
willy
I will give that a try for sure
well now its screwed up, the temporary fix on the injector line is temporary, just got a call from the Toro dealer locally the replacement line is discontinued, they have no suggestions how to get one, anyone have any suggestions, local shops are no help and Im out of ideas
any and all help is appreciated
thanks
   / Toro Groundsmaster 322D fuel issue #17
First u have to figure out what size ends u need.. both inj pump AND injector..
Hint: take a METRIC wrench, use the box end and fit it over the connector.. it’s either gonna be a 12mm or 14mm..
Now plug that # in Google as written & look for the correct ends..(12-14mm)
Ex: 6x2x600 injection pump line
They make a flexible emergency line w different ends but I haven’t looked for it.. I’ll leave it up to u..
Good luck
LOT: Assorted Pry Bars & Punches (A59076)
LOT: Assorted Pry...
240156 (A56859)
240156 (A56859)
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
Mini Excavator Hydraulic Auger (A55272)
Mini Excavator...
17501-FL (A56857)
17501-FL (A56857)
Club Car Electric Golf Cart (A57149)
Club Car Electric...
