torch info for projects
/ torch info for projects #1
Kendrick
Vermont
DK45S(Cab)
I am wondering what sizes of materials you guys often see while working projects. I am going to check out the torch equipment in my barn soon and if it is not up to snuff purchace some new.
I am trying to get a feal for what kind of material sizes are regularly welded on projects. I want to run a O/A setup and was trying to size materials and equipment for the job. I hope to get a nice stick and beyond in the not quite near future but untill then I will have to settle with o/a cutting/welding.
/ torch info for projects #2
I do a lot of fabrication and to be honest, most of my work is with tubing or material that is no thicker than about 1/4 inch. Not to say that I don't use larger material, it's just that 1/4 inch is probably the most common, 3/8 up to about 1/2 inch not uncommon, but certainly not the norm. I am starting to build a chipper from a 3 inch thick round billet as the core mass, but that type of thing is rare. Even the larger I-beams I sometimes work with are fairly light on the profile. I rarely need more than 225 amps on the stick welder.
/ torch info for projects #3
Kendrick, If you're asking what you can weld with an O/A setup the answer is almost anything if you have the right stuff. I have a heavy duty Oxweld outfit, a variety of tips and large tanks. I can weld 1/4 inch stuff with no problem at all. I've welded thicker in a pinch, but at that point its time to start the stick welder for speed and comfort. My stick welder is gasoline powered and if I have some small piece to weld it's often easier to just fire up the torch than to clear off all the junk I've piled on the welder. Also, if I have a thin section to weld, I'm much better with the torch.
/ torch info for projects #4
You'll find yourself using 1/4" material more than anything else. My experience is pretty much the same as scvguy. Thicker every once in awhile, but usually quarter (or thinner)...
/ torch info for projects #5
3/16 to 3/8 for most CUT equipment & ATV & truck stuff. I use a Miller 110v mig & a linclon stick welder with torch for cuts. The most valueable tool I purchased in the last 3 yrs was a portable bandsaw from milwaukee it gets 10 time the use of my torch. With the torch and bigger tip I have cut 4" material.
/ torch info for projects #6
Unless I'm making a trailer hitch,I rarely see much over 3/8" mostly it's 1/4" and under.Even rarer is a butt weld on two very thick pieces.
/ torch info for projects #7
I use the torch for heating stuck stuff and some cutting. Very little torch welding when you have a decent 240v mig.
jb
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2020 Nissan Murano SUV (A66738)
2020 Nissan Murano...
2017 Chevrolet Malibu Sedan (A66738)
2017 Chevrolet...
Hensley 16in. Bucket with Teeth Excavator Attachment (A68183)
Hensley 16in...
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
