Toplink brackets 1602D?
/ Toplink brackets 1602D? #1
project_X
Ottawa, ON, Canada
Kubota L235DT and L225
Hi all,
I am in the process of replacing the toplink brackets that attach to the back of my 1602D. I removed the bolts, but they were SAE (3/8), I suspect they must have been M10-1.5 or something. Does anybody know what they are supposed to be? I would like to fix the thread (as they are in rough shape, drill out and retap, or use a helicoil. Suggestions?
Cheers,
Rob
Hi all,
Cheers,
Rob
/ Toplink brackets 1602D? #3
</font><font color="blue" class="small">( Hi all,
Cheers,
Rob
)</font>
<font color="red">Helicoils were designed as a temporary fix, until a machine could be brought into a workshop and the hole either, oversized and retapped the next size, or welded and redrilled the origonal size.
Helicoils are only as good as the thread you screw them into.
Many years back during my apprenticeship in coal mines, we used then as a temp repair on machinery. They were forbidden to be used in bolts retaining covers on flameproof/explosionproof switchgear.
I personally haven't used them in years. I'd much prefer drilling and tapping to the next bolt size up, much better job and stronger too! </font>
/ Toplink brackets 1602D? #4
Cheers,
Rob
)</font>
I had already decided to drill and retap to the next SAE size up. I don't really like the looks of the Helicoil, thanks for your response.
thanks,
Rob
thanks,
Rob
/ Toplink brackets 1602D? #7
They are good for what they were intended for Rob, a temp repair in the field, until a machine could be brought into a workshop for repairs.
I'm surprised you didn't stay with a metric thread! Keeps everthing neat and tidy!
/ Toplink brackets 1602D? #8
Keeping it all metric would be great, but SAE taps and grade 8 bolts are much more acessible. As well, when I looked into it, I could remove much less material getting to the next SAE size over the next readily available metric.
/ Toplink brackets 1602D? #11
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Hi all,
Cheers,
Rob
)</font>
I personally haven't used them in years. I'd much prefer drilling and tapping to the next bolt size up, much better job and stronger too! </font> )</font>
Overall, I agree.... You should check these out.. They would actually make a stronger thread in most instances..
/ Toplink brackets 1602D? #12
Cheers,
Rob
)</font>
/ Toplink brackets 1602D? #13
</font><font color="blue" class="small">( </font><font color="blueclass=small">( </font><font color="blueclass=small">( Hi all,
Cheers,
Rob
)</font>
Overall, I agree.... You should check these out.. They would actually make a stronger thread in most instances.. )</font>
Now those are a huge improvement on Helicoils Greg!! They look stronger being a solid material!
/ Toplink brackets 1602D? #14
Cheers,
Rob
)</font>
/ Toplink brackets 1602D? #15
I've used heli-coils for years and never thought of them as a temporary repair, and never had one fail either. However, the newer style refenced above do look better, especially since they can't back out or run on thru, but then I've never had a properly installed heli-coil do that either. But, what if you want to remove it?
/ Toplink brackets 1602D? #16
/ Toplink brackets 1602D? #17
With all that said, does anyone know the metric size that should be there?
/ Toplink brackets 1602D? #18
Mine had been replaced with 7/16"., I think they might have been something funny like M11 -1.5. Some one who has a stock tractor will have to help with the actual size, I am interested as well. I drilled mine out and tapped for 1/2"SAE.
Cheers,
Rob
Cheers,
Rob
UNUSED WOLVERINE SWDB-11-84W HYD DOZER BLADE (A62131)
UNUSED WOLVERINE...
Bomag Roller (A63118)
2023 RIPPA R360 EXCAVATOR (A62129)
2023 RIPPA R360...
BUYERS PREMIUM & PAYMENT TERMS (A59910)
BUYERS PREMIUM &...
UNUSED WOLVERINE QC5-26-2DG QUICK ATTACH (A62131)
UNUSED WOLVERINE...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
