Toplink brackets 1602D?
/ Toplink brackets 1602D? #23
I think I tried a 10-1.5, but I'll try to double check tonight. I've got an assortment of 10's and 12's with me, so one of them is bound to fit.
/ Toplink brackets 1602D? #24
/ Toplink brackets 1602D? #25
OK. I got it measured tonight.
The toplink bracket on the YM1300 needs:
Bolt: M12-1.75 x 2.25" long Qty: 2
Nut: M12-1.75 Qty: 2
/ Toplink brackets 1602D? #26
/ Toplink brackets 1602D? #27
Maybe we were talking about a different thing, I was actually referring to the studs that hold the bracket on the back, mine were 10 mm.........
Ok, I get it, I was thinking of something else, my bad..............you're right about the size being 12mm on those.
/ Toplink brackets 1602D? #28
/ Toplink brackets 1602D? #29
For mounting the bracket on the 1300, it requires (on mine anyways), 2 bolts and 2 nuts. There are already two studs there that are utilized.
Also, I'd like to update the bolt size to M12-1.75 x 55mm
I got 60mm and had to use two washers to get it to fit.
2013 Land Rover Range Rover AWD SUV (A64557)
2013 Land Rover...
2016 PETERBILT 337 CAB AND CHASSIS (A65643)
2016 PETERBILT 337...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
Kubota Zero Turn Lawnmower (A65579)
Kubota Zero Turn...
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
