Toplink brackets 1602D?
/ Toplink brackets 1602D? #23
I think I tried a 10-1.5, but I'll try to double check tonight. I've got an assortment of 10's and 12's with me, so one of them is bound to fit.
/ Toplink brackets 1602D? #24
/ Toplink brackets 1602D? #25
OK. I got it measured tonight.
The toplink bracket on the YM1300 needs:
Bolt: M12-1.75 x 2.25" long Qty: 2
Nut: M12-1.75 Qty: 2
/ Toplink brackets 1602D? #26
/ Toplink brackets 1602D? #27
Maybe we were talking about a different thing, I was actually referring to the studs that hold the bracket on the back, mine were 10 mm.........
Ok, I get it, I was thinking of something else, my bad..............you're right about the size being 12mm on those.
/ Toplink brackets 1602D? #28
/ Toplink brackets 1602D? #29
For mounting the bracket on the 1300, it requires (on mine anyways), 2 bolts and 2 nuts. There are already two studs there that are utilized.
Also, I'd like to update the bolt size to M12-1.75 x 55mm
I got 60mm and had to use two washers to get it to fit.
2020 MACK P164T (A58214)
2020 MACK P164T...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
2014 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2014 FORD F-250 XL...
30ft Highway Trailer Co. Lowboy (A61307)
30ft Highway...
Harper TV130 High Dump Turf Vacuum Sweeper (A59228)
Harper TV130 High...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A59230)
2016 Freightliner...
