topdressing?
/ topdressing? #1
automech
SE PA
bx1500
I have a couple of acres of "lawn" that needs some help. I had a septic system re-done and have some spots that got a little washed out before the grass seed took hold. The ground is a little lumpy now, and I think I want to spread a little topsoil around to fill the low spots/holes and reseed. Is this called topdressing? Anyway I think that's what I need to do. I have a FEL to move topsoil, but is there an easy way to fill the bare spots without destroying the existing grass? I was thinking that I'm going to have to drop small piles and hand rake. Is a landscape rake too aggressive for this? Or am I wasting my time with this patch job?
/ topdressing? #2
I don't think you're wasting your time. I've used my FEL and my box blade but did it very slowly always keeping it high enough to just pull the top soil. I have ended by hand raking. If it's a big area it's always worth finding a way to stay in the seat.
If it's lumpy why not drag the box blade first?
/ topdressing? #3
/ topdressing? #4
I need to do the same as my "lawn" is very patchy and where ever there is a clump of grass it's a lump. I don't want to tear up the grass that is growing, just add to it and level/smooth some.
I've been thinking a section of chain link fence would smooth the fill out without pulling out the existing grass. The fill could be applied with the FEL (about my only mechanized option).
If/when you do this, let us all know what worked and what didn't :)
/ topdressing? #5
I guess you grow real grass... Mine is not very thick. When I had a full thick lawn I would top dress it once a year with some organic matter (something that looked like top soil but was even a higher organic content). I can't remember the name of the stuff. I would always do it in the early spring. Here is what I did....
1. scalp the grass as close down to the ground as I could (probably no more than 1/2" left)
2. apply organic material
3. smoth organic material (hand rake)
Worked great and ended up with the best lawn in the neighborhood after about 3 years. Also, mine was the only lawn that didn't need to be watered in the summer every day.
My current house was just built a year ago. The builder did a terrible job with the landscaping. Basically, I have about 1/2 grass, 1/2 dirt and rock. I plan to harley rake the entire 2 acres that is cleared closest to the house and reseed after adding top soil. The field is much worse.
/ topdressing? #6
I have had good results doing this by reversing my landscape rake and adjusting the top link so the tines kind of float without digging in. Otherwise, a landscape rake with gauge wheels would do the job. Best would be to rent a Harley rake and set the depth to low to work in the dressing, loosen the packed areas, and level it all.
2015 GMC 3500HD Flatbed Truck  6.6L Duramax Diesel (A63688)
2015 GMC 3500HD...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
2000 Malibu (A62613)
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
John Deere 6110M (A60462)
John Deere 6110M...
