TopDon Thermal Camera on sale
   / TopDon Thermal Camera on sale #1
LittleBill21
Elite Member
PA
Mahindra Max 26XL, White
I use this camera daily. This is the cheapest price I have seen in a while for it. Figure i throw it out there. I use it as much as my volt meter anymore. resolution is very high, plugs into the phone, and allows you take pictures, highest temperature etc. Really helps quickly diagnose issue, stuff that would take minutes takes seconds to find, like hot wires , bad insulation etc. I initially thought it might be a toy. I literally use it weekly with projects.
some photo's of it in use attached.
any questions let me know
   / TopDon Thermal Camera on sale #2
Those are fun. I borrowed my son's camera to locate a bee colony that moved into the rafter space between my basement and the floor above. Made it easy to locate the problem spot before I started dropping drywall from the ceiling.
I never thought it would be as useful as it is, I use it for everything under the sun. shocking how accurate it can see the temp difference, it shows up well for even 1 degree difference
   / TopDon Thermal Camera on sale #4
It looks like a USB-C connector, but doesn't show a great view of it, and the Chingrish text does not say. Is it USB-C?
yes, this model is for android, uses USB-C and has an extension cable for USB-C in case it doesn't fit, and or you want to move the camera independent of the phone
   / TopDon Thermal Camera on sale #6
That link is directed to Amazon.ca for me. I assume you are using Amazon.com … what’s the price on Amazon.com?
   / TopDon Thermal Camera on sale #7
I have played with one a couple times, and considered buying one, but haven't. I could see some uses, but not "needs", so I will hold off. I'm sure the prices will come down more over time. I also think it would be more practical with a viewer, then a dongle to a phone.
I got a free Endoscope, with a cheap viewer, and that is nice, so you don't risk your $1200 phone positioning it
it was 199, appears to be at 209 now.
I got a free Endoscope, with a cheap viewer, and that is nice, so you don't risk your $1200 phone positioning it View attachment 2147450
These things used to be like 1k 400+. I am not sure how much lower they are going to go. This is a thermal camera, doesn't work like an endoscope, this is for seeing temperature differences. It comes with an extension cable so you can position where you want.
   / TopDon Thermal Camera on sale #10
I have had a cheaper Seek thermal that plugs into the phone for years now. You can see what tubes in this radiator are clogged at a glance.
LMC G500-500A LOT NUMBER 232 (A53084)
LMC G500-500A LOT...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
2019 TAKEUCHI TL6R SKID STEER (A51246)
2019 TAKEUCHI TL6R...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
2025 New/Unused Wolverine Hydraulic Skid Steer Pallet Forks (A51573)
2025 New/Unused...
