westbrooklawn
Platinum Member
Installed top n tilt system on my L3400 a few years ago. 3 spool valve (just use 2), and cylinders with check valves. System worked fine until a week ago... Top cylinder will retract fine, but won't extend. I switched the two hoses for that cylinder at the valve connection points, and it works fine... Switch them back and original problem returns. Ideas?
