top n tilt install questions for a dk45
   / top n tilt install questions for a dk45 #1
justforme
New England
kioti rx6010
has anyone put one or seen one installed on one?
tia
jim
   / top n tilt install questions for a dk45 #2
I have top n tilt on my DK 35, which should be very similar to the DK 45 setup.
I have the factory dual rear remotes with CCM top n tilt cylinders.
   / top n tilt install questions for a dk45 #3
What is it you want to know about TnT ?
</font><font color="blue" class="small">( What is it you want to know about TnT ?
)</font>
are you running them off the rear remotes or the controls you can get with the tnt?
do you have any pics?
jim
   / top n tilt install questions for a dk45 #5
I'm running mine from my rear remotes .
Here is a picture of the control levers for the rear remotes
   / top n tilt install questions for a dk45 #6
The rear remotes where my TnT cylinders plug in.
   / top n tilt install questions for a dk45 #7
One more.
This is an older picture that shows the tie rod cylinders I use to run.
I am now using hydraulic top link and tilt cylinders from www.ccmachinery.com
thanks for the pics
i'll more than likely run mine off the remotes
i might end up running an electric solenoid valve so i can run a third cylinder for the offset of the rear blade.
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
Sterling 9500 (A56435)
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
EquipmentDealz (Shipping Terms and Instructions) (A59213)
EquipmentDealz...
2022 Schulte 2500 Giant Rock Picker (A56436)
2022 Schulte 2500...
2019 Dodge Charger (A56859)
2019 Dodge Charger...
