Top Links
   / Top Links #1
BobQ
Conn
Are top links all the same length and size if you stay in the same category? How about the pins?
Bob
   / Top Links #2
The top link extended and retracted lengths will vary depending on the tractor. The 3pt geometry specification used by implements might vary from the spec. One thing that tends to stay constant is the pin diameters for the top link and the lift arms.
Here are a few specification charts.
3pt geometry description #1
3pt geometry description #2
   / Top Links #3
Pins do seem to stay the same size.
depending on the attachment ..... you may need a longer or shorter top link and they do make them.
Example, if you can't get it short enough or you are getting to close to the ends of the threads when extended.
Ronald
Ranch Hand Supply
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
Forklift (A59228)
Forklift (A59228)
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
