Top Links
/ Top Links #1
BobQ
Conn
Are top links all the same length and size if you stay in the same category? How about the pins?
Bob
/ Top Links #2
The top link extended and retracted lengths will vary depending on the tractor. The 3pt geometry specification used by implements might vary from the spec. One thing that tends to stay constant is the pin diameters for the top link and the lift arms.
Here are a few specification charts.
3pt geometry description #1
3pt geometry description #2
/ Top Links #3
Pins do seem to stay the same size.
depending on the attachment ..... you may need a longer or shorter top link and they do make them.
Example, if you can't get it short enough or you are getting to close to the ends of the threads when extended.
Ronald
Ranch Hand Supply
2024 J&M TF215-40-G Soil Finisher (A63116)
2024 J&M...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
International Engine (A61568)
International...
BUNDLE OF 10' RE BAR (A62131)
BUNDLE OF 10' RE...
2020 International MV607 Cab and Chassis Truck (A61568)
2020 International...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
