Top Link
   / Top Link
Thanks guy . I found a place in Turkey they will do it to all my specs free shipping . The price is good to but am still looking and reading . H Any one ever hear from this place contrapart.com also 2 day shipping
   / Top Link #22
Even though I have access to a full shop, by the time I priced out stuff to work on my Cat 2 T&T figure what flow restrictor to use. Basically copying what fit rite sells, I don't get a warranty, might screw up have spend more, I just placed my order, I ordered the M7060 with two extra float valves.
   / Top Link
18 -26 is a 6 inch stroke ok what is the exact original top link close and open mesures
   / Top Link #24
Look at this link, get the asked for dimension. Top link
If the 6 inch stroke will work for you giving you the amount of travel needed in each direction, then you'll be good to go.
   / Top Link
I tried to messure mine but it bent and I cant screw it in and out all the way hopping some one will no.
   / Top Link
I can get a 19 3/4 close , whit a 8 inch stroke will that work , or is it to long. It a locale shop that has this
   / Top Link #27
It most likely is to long. You won't get enough retraction for some applications. You don't even need a top link to get the dimensions that are asked for in the link provided. Just hook up to your implement. Raise the draft arms enough so that the implement is level front-back and get a pin-pin distance for the top link. Based on that measurement you can determine if you will get enough travel from any of the top links that you are considering. It is best if you have a minimum of 3" of travel in each direction and a little more is better.
   / Top Link #28
Actually a LOT more than 3" is better, in part because you will end up using this handy gadget for so many things under varied circumstances. I recommend getting as wide a range as you can (fully extended to fully retracted) centered on the middle point most common for your most used implement.
   / Top Link #29
I agree 100%, more is better. But there are times when all that will fit on a particular tractor specifically the smaller tractors is a 4", 5", 6" total stroke. You need to be able to retract. He could put a 10" stoke unit on and it would work, but he would have zero retraction capabilities. it' is almost always best to have just a bit more retraction than extension from the level point of the implement.
There is a reason that I recommend an 18"-26" working length for the B series tractor. It is not just a random working length that I pulled out of the air.
A lot of people want to duplicate their factory top link. besides that is usually not possible with a hydraulic unit, I have found in many cases that the factory top link is actually wrong:shocked:, providing a working length that does not allow any retraction at all. Or very little (1/2") at best.
It is best to get the pin-pin distance with the implement level front-back and then determine what working lengths are available to best meet the requirements of said distance. Size of machine does not matter, it is all the dimensions combined what tells you what the best possible working length is.
Some examples for top link strokes. Most cat 3 hitches take either an 8" or 10" stroke unit where as the cat 1-2 Grand Ls and MX tractors take a 12" stroke unit. There are many LS tractors where a 6" stroke unit works out best.
Just my experiences, and I do this every single day. ;)
   / Top Link #30
Never heard of Contrapart but I did work on a large construction project in Turkey. From what I saw they have the best welders in the world and their manufactured products seemed to be first class. The obvious drawback might be the distance if you did have a problem with their product. And, of course it is always better to spend our money close to home.
2025 AGT H15R Mini-Excavator with Dozer Blade & Pilot Controls  (New/Unused) (A59225)
2025 AGT H15R...
SET OF 28L-26 DUALS (A52708)
SET OF 28L-26...
LOT: Assorted C Clamps, Irwin Quick Grip Bar Clamp (A59076)
LOT: Assorted C...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2008 Pierce Enforcer 61ft. Quint Ladder Fire Truck (A56858)
2008 Pierce...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
