Top Link
/ Top Link
Thanks guy . I found a place in Turkey they will do it to all my specs free shipping . The price is good to but am still looking and reading . H Any one ever hear from this place contrapart.com also 2 day shipping
/ Top Link #22
Even though I have access to a full shop, by the time I priced out stuff to work on my Cat 2 T&T figure what flow restrictor to use. Basically copying what fit rite sells, I don't get a warranty, might screw up have spend more, I just placed my order, I ordered the M7060 with two extra float valves.
/ Top Link
18 -26 is a 6 inch stroke ok what is the exact original top link close and open mesures
/ Top Link #24
Look at this link, get the asked for dimension. Top link
If the 6 inch stroke will work for you giving you the amount of travel needed in each direction, then you'll be good to go.
/ Top Link
I tried to messure mine but it bent and I cant screw it in and out all the way hopping some one will no.
/ Top Link
I can get a 19 3/4 close , whit a 8 inch stroke will that work , or is it to long. It a locale shop that has this
/ Top Link #27
It most likely is to long. You won't get enough retraction for some applications. You don't even need a top link to get the dimensions that are asked for in the link provided. Just hook up to your implement. Raise the draft arms enough so that the implement is level front-back and get a pin-pin distance for the top link. Based on that measurement you can determine if you will get enough travel from any of the top links that you are considering. It is best if you have a minimum of 3" of travel in each direction and a little more is better.
/ Top Link #28
Actually a LOT more than 3" is better, in part because you will end up using this handy gadget for so many things under varied circumstances. I recommend getting as wide a range as you can (fully extended to fully retracted) centered on the middle point most common for your most used implement.
/ Top Link #29
I agree 100%, more is better. But there are times when all that will fit on a particular tractor specifically the smaller tractors is a 4", 5", 6" total stroke. You need to be able to retract. He could put a 10" stoke unit on and it would work, but he would have zero retraction capabilities. it' is almost always best to have just a bit more retraction than extension from the level point of the implement.
There is a reason that I recommend an 18"-26" working length for the B series tractor. It is not just a random working length that I pulled out of the air.
A lot of people want to duplicate their factory top link. besides that is usually not possible with a hydraulic unit, I have found in many cases that the factory top link is actually wrong:shocked:, providing a working length that does not allow any retraction at all. Or very little (1/2") at best.
It is best to get the pin-pin distance with the implement level front-back and then determine what working lengths are available to best meet the requirements of said distance. Size of machine does not matter, it is all the dimensions combined what tells you what the best possible working length is.
Some examples for top link strokes. Most cat 3 hitches take either an 8" or 10" stroke unit where as the cat 1-2 Grand Ls and MX tractors take a 12" stroke unit. There are many LS tractors where a 6" stroke unit works out best.
Just my experiences, and I do this every single day. ;)
/ Top Link #30
Never heard of Contrapart but I did work on a large construction project in Turkey. From what I saw they have the best welders in the world and their manufactured products seemed to be first class. The obvious drawback might be the distance if you did have a problem with their product. And, of course it is always better to spend our money close to home.
/ Top Link #31
Excellent points MVRanch. Good info.
/ Top Link
Well got lot of good info here very nice . After reading , waching youtube I think the best set up for my b2650 is in the rang of 18 to 26 inch that will work best for me . Some time it get confusing but I think I got it now . Just too bad shipping and money exchange is so high from the USA id like to get one from
Fit Rite Hydraulics .Hope I can deal whit him in the future Brian really helpful and explane very good.
So I found a set up in turkey for $245.00 us that about $335.00 can free shipping also contrapart.com will make me one to my spec the rod dim is 1 3/8
18 1/2 close and 25 3/4 open that whit a 7 1/4 stoke I thing it will work for what am going to use it for .Again thanks guy for all the great info
/ Top Link
Here a pic of my top link will get better one on soon
/ Top Link
just whent in shop got a few pics. The stroke is about 7 inch
/ Top Link #35
MtnVR . I need to measure my top link on M9540 it is to long for the scraper blade (I can't get it high enough). When it all the way up it is not level(plumb).It needs to be shorter. I would like to keep in touch with you so I can evaluate what I need.Iwonder if I can use some type of an extension for other emplements.
/ Top Link #36
Take a look at this link, It will work for most any implement, not just a box blade and get the asked for dimension. I can make a recommendation from that. ;)
/ Top Link
still haven't try it yet waiting for my box blade .
/ Top Link #38
COUPMAN35....Did you get the top link from the outfit in TURKEY??? I'm looking for one as well and its primary use will be with a box blade, so I'm curious how your works out.
/ Top Link
Yes that the one I got from turkey .It well built and the price was rite 335.00$ plus 23.00$ duty Canadian and got it in 2 week
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A62129)
2020 CATERPILLAR...
2000 Dodge Ram 1500 4x4 Ext. Cab Pickup Truck (A61568)
2000 Dodge Ram...
UNUSED WOLVERINE SBM-12-72W 72" HYD SICKLE MOWER (A62131)
UNUSED WOLVERINE...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
1977 FURNAS BANDSAW W/AUTOMATIC SHARPENER (A62131)
1977 FURNAS...
