Top Link on Implement
/ Top Link on Implement #1
drewrowland
2021 Kioti DK50
Hi,
New to the tractor world and just bought an old used ford blade. The bottom links fit perfect in my Cat 1 hookup. However, the top link diameter on the implement seems to be larger and so my top link pin actually just slides ride through.
Is there a bushing I’m looking for to reduce the implement hole sizes or can I just get a different pin that does not slide through, but then is there an issue with the slop in the cat 1 pin size and the diameter of the holes on the implement?
hope this all makes sense and thanks so much!
/ Top Link on Implement #2
Maybe some big washers on each side?
/ Top Link on Implement #3
You can purchase a bushing to increase the diameter of your Category 1 Top Link pin to Category 2 diameter at Tractor Supply Store, Rural King or other farm oriented retailers. Probably every tractor vender too.
/ Top Link on Implement #4
Sounds like you have a category 2 top link. And yes there are bushings to change cat 2 to category 1 pins.
So the top link is definitely a cat 1, but it seems like the holes of the implement are a cat 2 or maybe some type of homemade fix.
/ Top Link on Implement #6
My Landpride blade has cat 1 lower pins but the top link pin is 1in dia instead of the std. 3/4, this was for a quick hitch. Landpride sells flanged bushing to reduce the top link pin holes down to 3/4, maybe yours is the same.
Sent from my SM-G715U1 using TractorByNet mobile app
/ Top Link on Implement #7
These are on the shelf at tractor supply
/ Top Link on Implement #8
I haven't seen any flange bushings there, just the standard spacers to increase pin diameters. The ones for mine are a split type and press in so they won't fall out when the pin is removed.
Yeah, a flanged bushing is what I was thinking I would probably need. I’ll go check TSC tomorrow. I guess I should probably also measure the actual diameter of the holes too.
/ Top Link on Implement #11
I was actually wrong on my top pin hole size, it's 1.25. Looking at the factory step bushings for the top link they are 1.25OD x.765ID x .70L
What blade do you have?
/ Top Link on Implement #12
I haven't converted all my pins to Cat 2. So ... in the mean time - I use bushings on my Cat 1 pins to fit my Cat 2 implements - as needed.
/ Top Link on Implement #13
Yep, flanged:
2005 Chevrolet Silverado 2500HD Duramax Diesel (A66408)
2005 Chevrolet...
100 Gal L Fuel Tank (A65643)
100 Gal L Fuel...
2010 Ford F-350 Crew Cab Diesel (A62679)
2010 Ford F-350...
2012 Chevrolet Equinox AWD SUV (A64557)
2012 Chevrolet...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A65563)
2007 International...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2008 Ford F-250...
