Top Link on a BX25 3pt Hitch.
   / Top Link on a BX25 3pt Hitch. #1
Delphicoder
Virginia
Kubota B3200
This is probably the dumbest question ever asked on here, but here goes anyway. On the BX25 top link 3pt hitch, what is the little square shaped loop on the outside of the cylinder used for? Is that where you can put a prybar or something to turn it after it is connected to an implement? I turn mine by hand, but have wondered if I am supposed to be using that as an easier way.
   / Top Link on a BX25 3pt Hitch. #2
Ding, Ding, Ding; you guessed it. It's just an assist to help turn the outer tube if/when needed. Some have the welded loop like yours and some have a hole through the tube where you can put a straight rod. Keep the threads greased on the top link & you probably will never need it anyway. I always lower the implement to the ground to lessen the load on the top link before adjusting.
   / Top Link on a BX25 3pt Hitch. #3
Yes, that is just for a screwdriver, or some such other leverage if the threads have paint in them, or the implement is heavy, etc.
   / Top Link on a BX25 3pt Hitch. #4
Also makes a handy place to put your PTO shaft chains.
Thanks! I will start to use it now, esp for the pto cover chains.
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52128)
Michelin CARGOXBIB...
ECHO SRM-2120 GAS POWERED WEED EATER (A51244)
ECHO SRM-2120 GAS...
2020 Cadillac Escalade 4x4 SUV (A50324)
2020 Cadillac...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2021 Doyle 8 Ton Trailer Tender (A52128)
2021 Doyle 8 Ton...
