Top Link on a BX25 3pt Hitch.
   / Top Link on a BX25 3pt Hitch. #1
Delphicoder
Virginia
Kubota B3200
This is probably the dumbest question ever asked on here, but here goes anyway. On the BX25 top link 3pt hitch, what is the little square shaped loop on the outside of the cylinder used for? Is that where you can put a prybar or something to turn it after it is connected to an implement? I turn mine by hand, but have wondered if I am supposed to be using that as an easier way.
   / Top Link on a BX25 3pt Hitch. #2
Ding, Ding, Ding; you guessed it. It's just an assist to help turn the outer tube if/when needed. Some have the welded loop like yours and some have a hole through the tube where you can put a straight rod. Keep the threads greased on the top link & you probably will never need it anyway. I always lower the implement to the ground to lessen the load on the top link before adjusting.
   / Top Link on a BX25 3pt Hitch. #3
Yes, that is just for a screwdriver, or some such other leverage if the threads have paint in them, or the implement is heavy, etc.
   / Top Link on a BX25 3pt Hitch. #4
Also makes a handy place to put your PTO shaft chains.
Thanks! I will start to use it now, esp for the pto cover chains.
2006 International 4400 LP Ambulance (A50323)
2006 International...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
PLEASE VIEW ALL PICTURES!! (A50774)
PLEASE VIEW ALL...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
