bumperm
Veteran Member
Old thread, but, if one has a DPCV top cylinder and needs a float function, would it not be possible to install a manual bypass between the cylinder's ports with a shut off valve between them? For normal operation the bypass is closed and the pilot check valves lock up the cylinder to eliminate creep. For float operation with tractor running, or to lower an implement or manually position the top cylinder with the tractor off, the bypass valve is manually opened.
bumper
bumper
