Top 5 Safety Rules
/ Top 5 Safety Rules
Wow! What an "eye opener" that NIOSH website is. I would recommend reading through several of the accidend reports.
/ Top 5 Safety Rules #25
Mornin Doc,
Well at least I do that !
/ Top 5 Safety Rules #26
Mornin Doc,
/ Top 5 Safety Rules #27
Prepare yourself mentally and physically for the project before you start it.
Stay Hydrated
Stop working when you are tired - whether you are finished or not.
/ Top 5 Safety Rules #28
Stay Hydrated
/ Top 5 Safety Rules #29
I usually start my tractor for the day standing alongside it, its parked behind my truck and I let it idle for a few minutes while I start the GMC and move it outside. As my JD is a hydro and has no attachments but the MMM, it seems to be quite safe to start it the way I do.
One of the Top 5 Safety Rules says DO NOT start the tractor when standing alongside it. My JD will not move unless there is someone sitting in the seat and a hydro pedal is pressed down. Am I being careless by starting it this way?
/ Top 5 Safety Rules #30
/ Top 5 Safety Rules #31
Any comments?
Possibly you intended this post for someone else? /forums/images/graemlins/confused.gif
With that being said I can not really comment on starting a hydro, as my TN will only start if I am sitting in the seat. That's the mentality I have had since day 1 of ownership and that's how I have trained others who might use it.
I would hate to be standing on the ground, leaned over holding the clutch with one hand and using the other to reach across the platform to turn the key, and have the tractor start moving - I am not as quick as I once was so I don't even take the chance on having that rear wheel climb my leg.
I also have a mental check list that I go thru before even starting the tractor and sitting in the seat allows me this opportunity - This is just my habit that I developed to make sure I am mentally "tractor ready" before the tractor is.
/ Top 5 Safety Rules #32
Any comments?
/ Top 5 Safety Rules #33
</font><font color="blue" class="small">( My JD will not move unless there is someone sitting in the seat and a hydro pedal is pressed down. Am I being careless by starting it this way?
)</font>
Depends how much faith you have in your safety switches. Mine will not start unless the High/Low range selector is in neutral. Do I start it not in the seat? Yes. Should I? No.
One problem that I can see is if you use someone else's equipment, especially older ag tractors that most likely will not have all the switches. If it is in gear (chances are so, especially keeping with the tradition that every farmer has a tractor with no brakes) you'd be in a mess if you started it from the ground.
/ Top 5 Safety Rules #34
)</font>
Tollster said:
Many think these are common sense, but you would be surprise how many are over looked. If you have been operating your tractor for the past year without stopping to think about any of these items. Perhaps you could just take a moment and do a refresher of the owners manual. It may surprise you on how complacent you have become. Which I believe is a main factor in accidents. Very rarly is it the newbe that gets hurt or killed, its the "experienced" operator.
You make a good point. A great deal of the accident reports that I've seen envolve some one that has done the job for years.
2019 CAT 259D (A60462)
Case CX350 C (A65053)
2016 Nissan Titan XD Crew Cab Pickup Truck (A61573)
2016 Nissan Titan...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
2019 John Deere R-4038 (A61306)
2019 John Deere...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
