Toothbar side plate gap
/ Toothbar side plate gap #1
13gef13
Mount Hallen, Qld, Australia
Yanmar ym1510d Kioti ds3510 Kioti EX5310
I am making a tooth bar for my FEL and I am upto welding it together but I don't know how much gap to leave between the side bracket ( with the bolt) and the side of the bucket. I thought 3mm or 1/8" each side but its only a guess. Too little and it will be too hard to put on/remove, too big and it'll be too loose. If somebody can tell me what their one is it would be appreciated.
Thanks, Geoff
/ Toothbar side plate gap #2
I think you got it right 1/8 inch or less.
/ Toothbar side plate gap #3
I'd leave between 1/16" and 1/8" total, not 1/8" on each side... that'd be way too sloppy
/ Toothbar side plate gap #4
Don't worry about too loose. You can fill any gap with washers/spacers.
/ Toothbar side plate gap #5
Thanks, Geoff
When I ordered my piranha toothbar, Harry asked for the inside measurement of my bucket to confirm that it was stock, and the brackets were no more than 1/8" inside the sides of our bucket.
In fact, because the bottom lip was a leetle bit warped from prying on BIG rocks, it ended up being a really tight fit needed some coaxing with a 3# persuader pounding on a piece of 2x6 to get it fully seated.
Thomas
/ Toothbar side plate gap #6
Two washers less than the bucket width.
Bruce
2012 MACK GRANITE-GU713 (INOPERABLE) (A65643)
2012 MACK...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
John Deere R4023 (A64126)
John Deere R4023...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
HEIN-WERNER 1TON TRANSMISSION JACK (A65643)
HEIN-WERNER 1TON...
