Toothbar side plate gap
/ Toothbar side plate gap #1
13gef13
Mount Hallen, Qld, Australia
Yanmar ym1510d Kioti ds3510 Kioti EX5310
I am making a tooth bar for my FEL and I am upto welding it together but I don't know how much gap to leave between the side bracket ( with the bolt) and the side of the bucket. I thought 3mm or 1/8" each side but its only a guess. Too little and it will be too hard to put on/remove, too big and it'll be too loose. If somebody can tell me what their one is it would be appreciated.
Thanks, Geoff
/ Toothbar side plate gap #2
I think you got it right 1/8 inch or less.
/ Toothbar side plate gap #3
I'd leave between 1/16" and 1/8" total, not 1/8" on each side... that'd be way too sloppy
/ Toothbar side plate gap #4
Don't worry about too loose. You can fill any gap with washers/spacers.
/ Toothbar side plate gap #5
Thanks, Geoff
When I ordered my piranha toothbar, Harry asked for the inside measurement of my bucket to confirm that it was stock, and the brackets were no more than 1/8" inside the sides of our bucket.
In fact, because the bottom lip was a leetle bit warped from prying on BIG rocks, it ended up being a really tight fit needed some coaxing with a 3# persuader pounding on a piece of 2x6 to get it fully seated.
Thomas
/ Toothbar side plate gap #6
Two washers less than the bucket width.
Bruce
2006 Genie Z45/25J Articulated Boom Lift (A64047)
2006 Genie Z45/25J...
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE TL-12-72W 72" HYD TILLER (A62131)
UNUSED WOLVERINE...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
