toothbar or toothbucket
/ toothbar or toothbucket #1
DIRTCUTTER
New Mexico
CK30 HST
Am going to purchase either a toothabr or a toothbucket. I move alot of good size rock, what do you think? which one would I get the most use out off ?
ck30hst
/ toothbar or toothbucket #2
I'm thinking if you've got the money and storage space (smooth bucket)? I would definitely go with the tooth bucket, I've damaged my toothbar a couple of times (kinda rough on my toys!), so I figure a dedicated bucket would be the best option :D . My 2 cents.
Will
/ toothbar or toothbucket #3
I have an "EZ" brand toothbar that attaches to my bucket (or comes off) in a matter of a few minutes. There are times that I want that straight edge on the front, so it's nice to be able to take it off. When on, it makes the bucket edge stronger by far.
EZ STANDARD TOOTH BAR ATTACHMENT
Roger
/ toothbar or toothbucket #4
For space? A toothbar..............two bolts and off it comes. Just remember it is heavy as it should be
/ toothbar or toothbucket #5
Toothbar or toothbucket? First question; do you have Quick Attach on your FEL? If not go with the toothbar, two bolts, 3-5 minutes to convert your bucket either way. Otherwise I would think it would be a huge PITA to go switch between buckets. Love my toothbar, it stays on my bucket 99% of the time. Will probably stay on until the snow flies and lands in my driveway. If money/space no object than a dedicated toothbucket to beat the crap outta is not bad either.
Either way put some aggressive teeth on the Kioti, really improves it's bite!
/ toothbar or toothbucket #6
I partly agree with Willie,
In a perfect world i would go quick attach and have the best of both.
It would also cut down on the wear and tear of using the same bucket
for multiple tasks that mabye it wasn't originally intended for.
Also, changing buckets is not the PITA that some may imply given the
long term benefits.
There are some good 3rd party QA available at pretty reasonable prices.
Kioti does not offer QA for the K130 loader. That's my .02
TomK
/ toothbar or toothbucket #7
Tom, Where did you chech for QA's that were reasonable? Or maybe reasonable is in the eyes of the buyer. I was interested in ATI brand. They only sell through dealers. Their mount will work with any standard skid steer attachment. I have a KL130 loader. Two local dealers put the QA mount for the loader at $700. There is a QA frame that can be welded on to the existing bucket or anything else you would like to attach for around $300. That's a little costly to me but I guess it depends on your uses and needs.
Vic
/ toothbar or toothbucket #8
I couldn't afford a toothbucket so I got the toothbar and am pleased with it. Now that we are getting close to the snow season I will take it off and be able to use my bucket to scrape snow.
What you learn when you own a Kioti, Did you know there is a rock band called "Toothbucket"
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
PALLET LOT OF MISC METAL (A63745)
PALLET LOT OF MISC...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
Year: 2011 Make: Chevrolet Model: Express Vehicle Type: Van Mileage: 118,735 Plate: Body Type: 3 (A59230)
Year: 2011 Make...
10" SPACERS (A63745)
