Toothbar installation with cordless drill
/ Toothbar installation with cordless drill #21
<font color=blue>same as if you hooked up an inverter and plugged your regular charger into that).</font color=blue>
You don't hook up an inverter to charge cordless tools. You hook up an inverter to plug 110v tools into.
/ Toothbar installation with cordless drill #22
I don't even own a corded drill anymore, my 18v DeWalt will drill in anything. I do use pilot holes for something big though. I use a 300 watt inverter in my truck for charging.
/ Toothbar installation with cordless drill #23
That is probably a record worthy of, at the very least, honorable mention in Rippleys. Worlds most expensive battery charger. /w3tcompact/icons/smile.gif
If all you are going to do is charge an 18v battery away fron the grid, a 300W inverter on a V8 engine is some serious overkill. Go get one of those cheap Coleman Recreational generators that burn about a quart of fuel an hour and put out 1100 watts. It will be far more efficient, will save wear and tear on your truck and will give you a little emergency power for lights and a radio if you need it. They cost about $200.
/ Toothbar installation with cordless drill #24
How about we install the inverter on the tractor, use a 3 cylinder engine or the battery to power it, forget the cordless drill, and use a 120 volt drill? Then you will always have a source of 120 volt power any where you take the tractor.
/ Toothbar installation with cordless drill #25
Gee, why didn't I think of that? /w3tcompact/icons/smile.gif But yes, running 110 direct is far more efficient that converting 12v to 110v to operate a charger to turn it back into 18v to charge another battery for an hour.
Lots of guys don't take their tractors out to those remote work sites. They have their PU because they are hauling tools and materials to make some type of repair on something. I think that a small generator used in combination with a deep cycle battery is the most efficient way to do that if the other option is to use the short discharge automotive battery to run the inverter.
If you are going to run an inverter off the vehicle cranking battery, the 2 or 3 cyl diesel engine is far more efficient than the 6 or 8 cyl gasoline engine. You will have to run the engine or the battery will quickly discharge and you won't be able to restart the vehicle.
/ Toothbar installation with cordless drill #26
My problem is as I get older I get more lazy every day. I would not want to carry a battery of any size to most of the places I need to have power. On top of that most of them are not readily accessable by truck. In fact most are only accessable by tractor or mule./w3tcompact/icons/smile.gif So for me, installing the inverter in the tractor just makes sense. I don't have to have 2 sets of tools, I don't have to drive back and and forth swapping between the tractor and the truck. And I don't have to maintain yet another little engine (on a generator).Besides, I never seem to have a truck when I need one./w3tcompact/icons/laugh.gifBut, whatever works.
/ Toothbar installation with cordless drill #27
I understand....and I use an inverter exactly that way but on my 15hp lawn tractor. I have a small trailer behind it with a deep cycle marine battery and the inverter. I run my electric trimmer off of it and I clip the marine battery to the lawn tractor battery to let the tractor charging system keep the marine battery topped off.
The tractor cranking battery couldn't provide enough amps for a long enough period.
I am going to mount a deep cycle battery on my Yanmar in front of the normal battery and isolate it like a camper battery so that the charging system will keep the marine battery up but when in use it won't drain the cranking battery. Then I will mount a 500 watt inverter attached to the deep cycle battery.
/ Toothbar installation with cordless drill #28
<font color=blue>You don't hook up an inverter to charge cordless tools. You hook up an inverter to plug 110v tools into.</font color=blue>
Perhaps I wasn't clear, but that was exactly my point: IF you have a charger that will run off of 12V DC, you can plug right in. You would only need the inverter if the only charger you had was designed for 110VAC and you wanted to plug in to a tractor or car. I was finally able to find a charger for my 18V Milwaukee Cordless system that would run off of 12 VDC, but it took some searching.
John Mc
/ Toothbar installation with cordless drill #29
Changing from 12v to 110v or changing from 12v to 18v to charge another battery is the same. Let me tell you why I believe that is not a good thing. Unless you are running your truck the entire time you are using the charger, you have a steady low amp drain on your vehicle cranking battery. It simply isn't designed for that type of discharge.
Take a car phone for example. You should charge the cell phone while driving but not while the vehicle is not running such as overnight. You take it in the house to plug it on for overnight charging. If you leave a steady drain on a cranking battery for extended periods of time you will cause the premature failure of the battery. Not to mention the fact that sooner of later you will not be able to start your car because it no longer has an adequate reserve of cranking amps.
I assume that since you went to the trouble of finding that 12v to 18v converter that you do that a lot. If I did a lot of charging of the type you describe, I would mount a deep cycle battery and isolate it from the vehicle cranking battery. That way you could charge all you want and never drain any power from the cranking system.
/ Toothbar installation with cordless drill #30
<font color=blue>Unless you are running your truck the entire time you are using the charger, you have a steady low amp drain on your vehicle cranking battery. It simply isn't designed for that type of discharge. </font color=blue>
Since the battery charges in less than an hour, and the current draw is rather low (6 Amps @ 12V), it does not significantly discharge my car battery. The draw is similar to leaving my door ajar so the two 8 watt (?) dome lights stay on for 4 or 5 hours. What really shortens the life of lead acid batteries is deep cycling them. A shallow drain has little effect. (researched a bunch of this when I was looking at setting up my new house "off-the-grid" using wind and solar power to charge a bank of batteries). On the other hand, I don't generally charge more than one battery (or on rare occasions two) without running the vehicle.
<font color=blue>I assume that since you went to the trouble of finding that 12v to 18v converter that you do that a lot.</font color=blue>
The charger was made by Milwaukee. The tough part was finding out that it even existed. Looks just like their 110VAC unit, but has a cigarrette lighter plug on the end. Once the battery is charged, the power draw drops to almost nothing. I don't use it particularly heavily, I just needed something to work with before I had power out at our homesite... sawing/screwing/drilling by hand got old quickly, as did hauling wood back into town to cut with a circ saw.
John Mc
/ Toothbar installation with cordless drill #31
<font color=blue>What really shortens the life of lead acid batteries is deep cycling them. A shallow drain has little effect. (researched a bunch of this when I was looking at setting up my new house "off-the-grid" using wind and solar power to charge a bank of batteries).</font color=blue>
Bingo!!!!!!!
It isn't the shallow drain that gets you. It is the combination of shallow drain and then cranking the engine that gets you. Deep cycling is precisely what you are doing when you drain 6amps from your cranking battery for an hour and then hit it with a big amp drain when you start your engine. It is a drain/recharge cycle that your cranking battery isn't designed to handle. That is why campers use auxiliary batteries isolated from the cranking system to run 12v electrical accessories.
I went through 2 Die Hards in 2 years before I figured out it was the drain my radar detector was placing on the battery that was killing them. It was pluged into an auxiliary plug that powered it all night. Every morning I was cranking with a battery that was not fully charged, ie, I was deep cycling the battery more than it was designed to.
The two worse things you can do to a battery is undercharge and overcharge. A shallow drain before you crank the starter is the same thing as undercharge.
/ Toothbar installation with cordless drill #32
I don't know what my car battery is rated for, but I've gotta believe that 6 amp-hours is on the order of a couple of percent of the total capacity. I can't beleive that such a small percentage has a significant effect. If it did, more people would be having problems with the drain caused by their clock, alarm, and other "always on" accessories if they let the car sit for a couple of weeks.
John Mc
/ Toothbar installation with cordless drill #33
Well your're talking about milliamps with radio memories and clocks but yes, if it was someone's habit to let a car set unused for a couple of weeks and then drive it for a day and they always did that, it would reduce the usable life of the battery. Just about any battery manufacturer will tell you that if you leave a car sit for long periods to hook a trickle charger up to it to keep it charged up. If you are going to store a car, you take the battery out or at least disconnect it.
What I am telling you about battery is not speculation. It is from experience. I ate up two die hards in two years before I figured out it was from putting a load on it just like the one you describe. That is why I use a second battery now. One designed for deep discharge.
2015 Jeep Renegade Latitude SUV (A64557)
2015 Jeep Renegade...
2010 Dodge Grand Caravan Van (A64557)
2010 Dodge Grand...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
2020 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2020 INTERNATIONAL...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
2007 JLG G6-42A 6,600lb 4x4 Rough Terrain Telehandler (A64553)
2007 JLG G6-42A...
