toothbar for fel
/ toothbar for fel #1
hambob
I have been reading about toothbars for the fel. I know little about them. Do I need to get one from my Kubota Dealer or after market. What is a fair price. Keep in mind I am cheap. I understand they are bolt on. If so, does the bucket need to be drilled. I also want to know the best place to have a hook put on the bucked, or should it be some other place on the loader?
/ toothbar for fel #2
</font><font color="blue" class="small">( Do I need to get one from my Kubota Dealer or after market )</font>
Since you want a good one cheap, you probably want Markham. However, I like mine from H&H Sales . H&H prefers selling through your local dealer. Markham does direct sales.
</font><font color="blue" class="small">( I understand they are bolt on. If so, does the bucket need to be drilled )</font>
Yep. I used a 1" hole saw. No problem.
</font><font color="blue" class="small">( the best place to have a hook put on the bucked )</font>
I would recommend not less than 2 chain hooks, one on each side of the top of the FEL bucket. You should be able to find photos of well-installed chain hooks. Try searching.
A toothbar and chain hooks are likely to be the 2 things that give the most improvement in functionality per dollar spent.
/ toothbar for fel #3
Attached is a picture of my bucket.
I have 3 bucket hooks, 1 on each side and 1 in the middle.
The toothbar is a WR Long, cost with shipping was around $300.
/ toothbar for fel #4
I agree with what the other guys said. My toothbar came from Woods and I paid around $300 for it.
/ toothbar for fel #5
hambob, One thing to consider, when getting a tooth bar, is the edge of your bucket. If you get a bolt on edge on your bucket the spacing of the teeth becomes critical because the teeth will fit in-between the protruding bolts of the bolt on edge. On Markham's web page they say that their toobars are designed for buckets without the bolt on edge. <font color="blue"> Markham - "They will Not Fit with Bolt-On Cutting Edges, Unless you are willing to remove all the bolts in that cutting edge before installing our tooth bar."
</font>
I have a bolt on edge and my dealer had to give all the measurement of the bolts to FFC so the toothbar they built would not have to go over the bolts.
Hooks - One thing to consider here is that when you pull with with the hook it is best to have the load equal on the bucket so you do not twist the loader. My dealer would only install (free) one in the center for this reason. I can see where three would be good for holding things in the bucket. I just would not pull from an end hook.
/ toothbar for fel #6
I found that I could buy from my MF dealer at a competitive price and they installed it when prepping for delivery, but I'm not familiar with the Kubota lineup.
I will suggest 3/8 grab-hooks where-ever you decide to put them. With the 3/8 you can use a 1/4 chain or the 3/8. I have one on each side of the bucket at the top, about where it attaches to the FEL arms.
You'll really appreciate the toothbar for digging, clearing brush, etc.
/ toothbar for fel
Thanks for all the advice. I just called the dealer and he will install a toothbar for $325 before deliveryplus he will space three hooks along the top. His family has had farm equipment dealership for close to 70 years, and ought to know better than me where and how to attach. He can also do it easier. I may be cheap, but I am also lazy. Otherwise I would just tell the wife and kids what I want moved. Its easier to do it with my toys.
/ toothbar for fel #8
<font color="blue"> he will space three hooks along the top. </font>
In the photo Vince posted you can see a grab hook in the center and slip hooks at the ends...
My choice was a slip hook in the center and grab hooks at the ends...
There have been times when I told myself I was glad my slip hook was in the center, probably because it was easier to take up the slack chain by pulling from the side before hooking into the grab hook.
Wonder what configuration of hooks is best? Maybe all are equally good. I am almost certain that I would not want all slip hooks though. At least one grab hook would be a necessity in my book.
Might not hurt to ask the dealer what kind of hooks he is welding on, just to be sure.
/ toothbar for fel #9
just wondering , would there be any advantage to all 3 hooks being GRAB HOOKS?
/ toothbar for fel #10
txdon, did you have to go through the dealer? You made my day in that Markham was going to make me remove my cutting edge. I didn't want to do that. Looks like FFC will let me keep it and have the toothbar. If you don't mind me asking, what did that toothbar cost and which did you get? Did you get the standard, heavy duty or extra heavy duty?
/ toothbar for fel #11
jhbusa, I went through my dealer, my dealer is the one who suggested FFC. I got the Extra Heavy Duty toothbar.
The cost last year was $620 for a 6' toothbar.
Ok, you can start breathing again. Breath! Breath ....
/ toothbar for fel
My e-mail server has been down the last couple of days, then my daughter was on line looking up things for her homework, so I have just had a chance to look at the posts. Good Picture of the hooks, I was not sure of what a "slip hoop" was until I looked. I think the dealer will be doing all grab hooks. Have not had a chance to call him. At this point, I am so looking forward to getting the tractor that I don't care, so long as it has hooks. I pay of being that way a lot. Sure could have used it yesterday and today. Was off with a sick child and had a few hours to work. Did manual labor instead. Temp in the 30's and 40's. I enjoy the discussions.
/ toothbar for fel #13
Ouch, but it will be worth it if I can keep my cutting edge. Thanks for the info.
/ toothbar for fel #14
txdon,
Where did you get that canopy? I need to order one. I've been leaning toward aluminum treadplate like I had on my 3650 (no rust).
Trump 2025 Sign (A64557)
Trump 2025 Sign...
Swict 84in Bucket Skid Steer Attachment (A64553)
Swict 84in Bucket...
2019 CATERPILLAR D3K2 LGP CRAWLER DOZER (A65053)
2019 CATERPILLAR...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
