Forks Toothbar & Bucket Forks
   / Toothbar & Bucket Forks #1
Ed_Indiana
W. College Corner, Indiana
Kubota B-7800
I have been with this forum for 4 years and log in everyday. I have not posted many times, but would like to share a toothbar & bucket forks that I recently made with the help of a machinest friend of mine. The toothbar will flip back into the bucket and allow me to attach the forks. Also the toothbar is almost flush with the bucket bottom to allow for smooth back dragging. The forks attach with spring loaded ratchets with the bolt attached and allen screws on the bucket floor. They are heavy duty.
   / Toothbar & Bucket Forks #2
Great job at making the tooth bar the way you need it to be.
I like it!
   / Toothbar & Bucket Forks #3
Congratulations on a picture perfect set of mods! We should all have machinist friends like you have!
Rusty
   / Toothbar & Bucket Forks #4
Obviously high quality work.
   / Toothbar & Bucket Forks #5
That is a really imaginative design! Great job! Sure beats having to take the tooth bar on and off all the time.
   / Toothbar & Bucket Forks #6
Very nicely done. What is the material that is used for the forks? :confused: And.....if high strength material (as it appears) how did you bend the 90 degree? I like the way the forks attach.
Edit....On closer inspection, it appears the forks are welded at the 90 degree I had inquired about.
Yes, the forks are welded at the bend. Will get back to you on metal specifics, but I do know the bucket would bend before the forks would. I have of course scooped up many a large brush pile, also railroad ties, telephone poles ( which I later cut up intp 8' fence brace post) and I lifted good size trees for chainsawing into firewood.
   / Toothbar & Bucket Forks #9
Hmm, the tooth bar looks like it is patterned after one (the FTB style) from WR Long, though yours flips into the bucket further than the WR Long one does.
   / Toothbar & Bucket Forks #10
Looks Great! I like that way it protects your cutting edge when really working is hard material. Hope to build one myself this summer.
2005 Mitsubishi Lancer ES Sedan (A54815)
2005 Mitsubishi...
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A55745)
2016 FREIGHTLINER...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2006 Vermeer BC1000XL Towable Brush Chipper (A55851)
2006 Vermeer...
