tooth bar
/ tooth bar
Re: tooth bar and cutting edge
Of course, I don't own a boxblade and have only fiddled with a few...But....
<font color=blue>...Isn't a boxblade just counterweight ...</font color=blue>
Don't let Bird hear you say that... /w3tcompact/icons/smile.gif
Bird is probably the first man that comes to mind on getting the most mileage out of a boxblade... especially with his TNT...
If it can be done with a boxblade... Bird can do it! /w3tcompact/icons/wink.gif
/ tooth bar #22
Gosh, John, I wish I was as good with it as you make me sound./w3tcompact/icons/laugh.gif I did use it an hour or so yesterday; don't know how I ever did without TNT.
Bird
/ tooth bar #23
JimI,Yeah I hope we don't get drug behind a tractor.../w3tcompact/icons/laugh.gifGreat thread too...yeah they got us GM's back to everybody being just GM's...Happened about 1999.Ah well few things last for ever...
Hey,how about a couple of heavy springs(one on each side) instead of a lock..?On the tooth bar.With a stop stud to keep from over stretching the spring...Would prob be a tight fit but hey while you're experamenting most anything goes...Some thing like that might be strong enough to hold the bar back for leveling gravel or sand mabye even chert depending on the angle you hold the bucket...Just a quick thought....
Lil' Paul
Proud owner of TC21D
Laziness is the Father of invention.../w3tcompact/icons/laugh.gif
/ tooth bar
Here's a toothbar mounted with a bolted on heavy duty bucket cutting edge...
/ tooth bar #25
Very cool, John. That's gotta be one "Diggin' Mama." Who says you can't have it all?/w3tcompact/icons/cool.gif/w3tcompact/icons/smile.gif
JimI
/ tooth bar #26
Speaking of tooth bars, I bought one but haven't installed it yet. I'm still trying to figure out how to drill two 3/4" holes in my bucket without spending $30 on a drill bit that I will probably never use again. Any ideas?
Maury Jacobs
/ tooth bar #27
Maury,
If you had ask for any "good ideas" instead of just ideas I would not have responded./w3tcompact/icons/smile.gif I just added a home built bucket mounted mower that required two 3/4 inch holes in the bucket.
The first hole I drilled sucessively to 5/8 " and filed to 3/4". For the the second hole I went to the hardware store and bought a 3/4" bit. The second hole took less time, including travel than the first. I am now thinking of the many ways I can use my new $39 dollar bit. With a hand drill it is really easy to cock the bigger bits and take a chip out of the cutting edge, so go slow near the end of the cut.
Al
/ tooth bar #28
Al, Bucket mounted mower? Are pics available?
Maury, my toothbar only needed 1/2 " dia. holes. Some use a cutting torch to make the holes.
/ tooth bar #30
DFB,
Boy, you sure know how to rub it in. I think I'm the only one on the board without a digital camera. I sat by the chimney all night Dec. 24/25 and zip/not/nothing./w3tcompact/icons/frown.gif Maybe next year.
The mower is really pretty simple. Three 5 hp engines left over from a prior tow behind rig. These set side by side on an angle iron frame, that sticks out in front of the bucket. It piviots from two holes in the bucket in the same location as the tooth bar holes. Two chains from the rig to the top of the bucket (one each side) limit the down travel to bucket horizontal. Two 13" wheels on the front so I can drag slopes. It's a noisy rig to run but does a good job on blackberries and light brush, things I can't get at along the fence lines with the rotary cutter or the DR.
Looks almost store bought, I painted it Kubota gray and orange. <font color=orange>/w3tcompact/icons/smile.gif</font color=orange>
Al
1995 John Deere 7400 (A60462)
1995 John Deere...
2019 John Deere R-4038 (A61307)
2019 John Deere...
MASSAGE CHAIR (A58214)
12' CONTAINER (A52706)
INSPECTION (A61166)
INSPECTION (A61166)
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
