TOOTH BAR
/ TOOTH BAR #1
Lazy
Platinum Member
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
Hi
I had to cut my tooth bar so it would be long enough, but I think I got a good deal on it for 200 dollars. see attachment.
Charlie
/ TOOTH BAR
after bridge welded in on top, stil need to weld the bottom
Charlie
/ TOOTH BAR #3
Ihad to cut mine and then weld it for the 5030. I used a plasma cutter (much neater). I also got another tooth and weldment and added it on. I have an ATI.
/ TOOTH BAR
Hi
A plasma cutter is my next thing to buy, but with an angle grinder it only takes about a minute to clean up after using a torch. I also used the torch to cut the holes in the bucket.
Charlie
/ TOOTH BAR #5
I don't use a gas axe for much. I prefer a drill for holes. I don't like the spatter. Besides, it destroys the paint.
If I have something too thick for the plas cutter, I cut it with a Metabo cutoff wheel or my horizontal band saw.
If you are going to get a plasma cutter, get an inverter model. They run cooler and start easier, especially if they have a pilot arc.
/ TOOTH BAR #6
Daryl
How do you like yourATI toothbar?
I am in the market for one and have seen their ad
Thanks Point
/ TOOTH BAR #7
Nice torch work! I can't drill a hole that round!!! /forums/images/graemlins/tongue.gif
/ TOOTH BAR #8
My ATI bar has been through 2 tractors now. No problems and replacement teeth are available. I like the way it fits to the bucket.
/ TOOTH BAR #9
I would have loved to have what I needed when I made the holes for my Woods toothbar, but I only had 1/2" drill bit and had to use my dremel tool with a grinding stone to bring them to 3/4". Took a while, but made nice holes. Dad always did like to call me hard way johnson. John
2014 FREIGHTLINER M2 4X2 S/A CNG FLATBED WITH CRANE TRUCK (A66091)
2014 FREIGHTLINER...
More info coming soon. (A64557)
More info coming...
2006 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2006 WINSTON...
2011 MIDLAND  GOOSENECK SPOOL TRAILER (A68842)
2011 MIDLAND...
2003 Honda Pilot AWD SUV (A66738)
2003 Honda Pilot...
2014 Evinrude 2-G 225 HP Outboard Boat Motor (A66738)
2014 Evinrude 2-G...
