toolcat precleaner installation
/ toolcat precleaner installation #1
albert
middle Tn
Toolcat D
I'm considering adding a precleaner to my 5600 D Toolcat. Dealer price is $298 but installation would cost an additional $300. Installation looks pretty straightforward. Has anybody done this installation. If so, how hard was it to do? Any tips?
/ toolcat precleaner installation #2
I did mine a couple of years ago on my 5610 F series. It took me around 2 hours to complete the install. The kit included all the parts and step by step instructions. If the install method is similar to mine my best advice is to make sure you face a sharp hole saw and a strong corded drill to make the hole in the body. Mine was double walked and took it slow adding some cutting oil during to keep the hole straight between the two walls. Also ended up using some spray lube to get the intake pipe to couple to the existing cleaner with the kits included rubber hose since it is slightly too small to makeup the connection.
Sent from my iPhone using TractorByNet
2014 Chevrolet Silverado 3500 Crew Cab Utility Flatbed Truck (A60352)
2014 Chevrolet...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 Land Rover Discovery Sport 4WD SUV (A61569)
2016 Land Rover...
2009 PETERBILT 340 (A60736)
2009 PETERBILT 340...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
