Comparison Toolcat issue
/ Toolcat issue #1
catdozer
Platinum Member
john deere
Looking for some help have a toolcat i bought not long ago and when you go to start it it blows the fuse. Sometimes it will start and just hydros will work and not go forward or backward. Forward reverse light flashes. Sometimes it won't start at all just beeps when you try to start it.
/ Toolcat issue #2
What fuse does it blow?
Any signs of rodents chewing on the wires?
/ Toolcat issue #3
When it does start and lights flash, push "hold for code button" as see of there is a numeric code.
/ Toolcat issue
Well replaced ignition fuse. And all has been well since. Seems to be dumb founding me.
/ Toolcat issue
No codes either.
/ Toolcat issue #6
Once the problem, in this case flashing lights, goes away so does the code. Only way to find out what the code was (if any) is to have a dealer connect his service analyzer to download the code history. If it happens again push the code button before turning key off.
EZ Trail 3400 Seed Tender Wagon (A64047)
EZ Trail 3400 Seed...
New/Unused Quick Attach Rock Breaker (A61166)
New/Unused Quick...
2014 Volkswagen Jetta Sedan (A61569)
2014 Volkswagen...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
2021 KLX 300 Motorcycle (A61166)
2021 KLX 300...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A61166)
New/Unused...
