Toolcat and V417
/ Toolcat and V417 #61
Thanks for the pics Xfaxman.
Had my local dealer deliver one and have been "playing with it" all weekend. Rocked and regraded the drive, cut the overgrown field with a brushhog and the 3 point and dug some dirt to make a shooting range. Strongly leaning toward purchase.
/ Toolcat and V417
You're welcome. Buy it, you'll like it. :D
How wide was the brushhog? I have only used the PTO with a post hole digger.
/ Toolcat and V417 #64
When running my front mower or rear rotary cutter, then I change directions (F-R), the mower's hydraulics will slow then start again. Does this happen with your G series units? It does not do it if I keep my foot on the go peddle slightly when changing directions.
/ Toolcat and V417
I was wondering if that ToolCat would handle a shredder on the front.
Yep, this one is 7' wide, weighs 1800 pounds:
In some brush, before:
Cut it and backed up:
In thick grass:
/ Toolcat and V417
Yep, it does. But it didn't happen on our F.
/ Toolcat and V417 #67
Here is a good fuel funnel that fits fillers necks on the side of the toolcat and others. I wish I had this when I had my Kubota RTV900! It is a Scribner 6115 14" D-shaped 45 degree funnel. It does not come with a filter but I'm showing it with a paint filter. This thing is HD, BIG, and well shaped.
/ Toolcat and V417 #68
The brush hog is 6ft. It is an old Land Pride unit. Not sure of the weight. I am keeping it after they do the 500 hour service and change all the filters. Just too useful a tool. Far better for what I need to do than my JD 310B or the old Ford I had, but in fairness it is 4 times the cost of those old machines. Worth every penny I believe.
/ Toolcat and V417
Good to know it handled the 6ft. OK.
Is the Toolcat a D Series or F?
/ Toolcat and V417 #70
View attachment 567846View attachment 567847View attachment 567848
Thanks for that- it might also be just the thing for my genny's oil fill port- a PITA to use if ever there was one...
Links: SCRIBNER Funnel - 14 in D-Shape - 45 Degree - Plastic - Red - Each # 6115R -cheapest, but on backorder.
Amazon.com: Scribner Plastics 6115DB Dark Blue 45 Degree 14" D Funnel: Automotive Dark Blue is 22.30 with prime shipping.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
1988 FONTAINE 45' STEP DECK LOADER TRAILER (A60736)
1988 FONTAINE 45'...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
AGT Industrial ATK-B1000 2 Post Car Lift (A60463)
AGT Industrial...
