Toolcat 5600 D Error code 18-07 Spool Lock Open
/ Toolcat 5600 D Error code 18-07 Spool Lock Open #11
Hi FoxXcavation, Thanks for the information in your post. I have a 2008 Toolcat 5600 and I have just started have a problem where my lift arm is locked in the down position. The tilt seems to work fine. If I shut the Toolcat off for a short period of time and come back it functions normally for maybe 10 minutes and then this whole series of events repeats itself. I have not done any type of work on the Joystick and so I don't know where that coil is located, please help me with that. Did you need to replace that coil and if so do you happen to have that part number. Was it difficult to replace and approximately how long did it take you to change the coil. Have you had any similar issues after you replaced that coil. Thanks from Wyoming.
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2024 Linx 6'x14' Trailer (A60462)
2024 Linx 6'x14'...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
HYSTER S50FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S50FT...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
