Toolbox
/ Toolbox #1
soarkrebel
garland county arkansas
Kubota L3000DT
I was in need of a better way to carry tools on my tractor. i was in a sutherland hardware store and saw these little toolbox's called gadget box's.
i bought one and removed the handle and filled the holes with pop rivets. i then drilled three holes through the box and the right fender of my tractor. on a L3000dt kubota it fit perfect.
i painted it kubota orange and it now looks factory.
here is a link to stack on.
web page
Works great and is small enough not to hamper anything.
/ Toolbox #2
Nice job, I'll bet! Too bad I can't see it! Hint, Hint!
I like the classic look of that box; a little more stylish than a big square one. Did you use anything between the box and fender, like a flat washer or a piece of gasket material? I thought about doing that but I wondered if it would make the box shake worse and gouge the fender over time.
/ Toolbox #3
I have one of those that I carry around in the bed of my truck. I bet it looks nice mounted to you tractor (another hint hint) /forums/images/graemlins/grin.gif . One word of caution: on mine the latch got loose and will pop open at the most inopportune moment, even while riding in the truck. I can bend the lip or the hasp and it holds for a while. You may not have that problem since you don't tote yours.
/ Toolbox
You know i am going to have to get a digital camera.
I painted on some plasti dip on the bottom of the box . but if you tighten it up good it won't move.
I havent had any trouble with the latch yet but if i do i think i will add a new latch. a drill bit and some pop rivets and you can do anything. /forums/images/graemlins/grin.gif
it has enough room to put tools and a bottle of water. and it's easy access. i always liked the tool box on my grandfathers ford 3600 and hated that mine had none. now i have a palce to put stuff.
2018 Manitou MLT960 ST4 S2 13,000lb 4x4 Rough Terrain Telehandler (A66734)
2018 Manitou...
2014 PETERBILT 567 (A67714)
2014 PETERBILT 567...
PORTA POTTY (A68842)
2012 PROCO KILL TRAILER (A67714)
2012 PROCO KILL...
2019 JCB 409-T4 WHEEL LOADER (A65056)
2019 JCB 409-T4...
2018 FORD F-150 (A67714)
2018 FORD F-150...
