Tool to stretch spring
   / Tool to stretch spring #1
JoshuaB
Gueydan
White American 80 / John deere 1530
Trying to fix an old john deere 210 disc. Several of the scrapers need new springs but for the life of me I can not stretch them long enough to attatch them. Anyone ever seen a tool made to stretch a spring? I am at work now, can get pics of spring and Disc on thursday if needed.
   / Tool to stretch spring #2
Use a ratchet strap to pull the spring over the seat.
   / Tool to stretch spring #3
Yes let's see a picture of what you are trying to do.
Ok, will update Thursday when I am back on land with some pics
   / Tool to stretch spring #5
I have several special spring tools for exhaust systems held together with springs. Look for motorcycle tools.
   / Tool to stretch spring #6
Not sure if it will work for your application but the old automobile drum brake spring tool might work. Been so long since using it but if I recall correctly, you simply used the long slim handle that had a concave end that rested on 'something' and you could stretch the spring and slide it off onto the thinga-majiggy. Dang it's been too long.
The problem with using a brake tool is that the springs dont go over pegs, they go into holes on the scraper arms so as far as I can tell they need to be stretched and twisted at the same time so that the hooks on the ends of the springs can be inserted. Really seems like a poor design and from my searching Ihave not found anything good said about this disc online, or from anyone local for that matter either. but it is all I have to work with.
I had a thought last night about getting a couple dozen self tapping screws and making them act as pegs to mount the springs too. I just worry that the metal would be too brittle and they would just snap from the side load.
294331ac-5108-474d-8f8c-85a0fa1e24a9.jpg Found a picture online of how it is set up.
I guess my problem is not so much the pulling of it, Hosspullers suggestion of a ratchet strap would make that easy enough, but the pull AND twist to hook the spring is the trick.
   / Tool to stretch spring #10
Looks like a job for Armstrong & a good pair of Vice Grips to pull and twist the end into the hole.
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2017-2023 Chevrolet Silverado Pickup Truck Bed (A49461)
2017-2023...
KLEEMAN MS192 MOBILE SCREEN (A51242)
KLEEMAN MS192...
STORAGE FEES (A51219)
