bigtiller
Super Member
- Joined
- Feb 1, 2006
- Messages
- 7,351
- Location
- central Iowa
- Tractor
- John Deere 2720 John Deere 3039R John Deere Z545R
Yep, but the guy in the store selling them didn't.
So, did you know that the coupler on a grease gun is adjustable?
Stupid auto correct, I fixed it.While I got what you meant, that is one fine typo! Really makes it read funny![]()
The Phillips is wonderful at doing exactly what it was designed to do: Cam out under load. Phillips designed it to be driven with an unclutched power driver, and cam out before it could exert enough torque to snap, or tear out the sheet metal. It does that really well.PZ drive works much better and should not be particularly more expensive, a screw design that handles torque so badly as Phillips is pure junk and thankful it's almost dead for all serious use.
A myth to cover a bad design, it was not in the patent application, destroying the screw as a feature is not good.The Phillips is wonderful at doing exactly what it was designed to do: Cam out under load. Phillips designed it to be driven with an unclutched power driver, and cam out before it could exert enough torque to snap, or tear out the sheet metal. It does that really well.
Phillips have no reason to exist in any new products in 2021.Just because it wasn't in the patent, doesn't mean it isn't used for that reason. Also just because it isn't perfect doesn't mean it's not useful.
Ahhh,, yes,, BUT,, 19mm and 3/4" sockets are perfectly identical, (within 0.05") and interchangeable,,Now I've learned two things this month about tools. The first is that 1/2" and 13mm really aren't the same thing. (1/2" is 12.7mm)
Everyone in the world has Phillips screwdrivers. A limited number have other options.Phillips have no reason to exist in any new products in 2021.
